Hi all
Anyway of triggering a PDM input of a +12V signal without resorting to a pull down resistor?
Thanks in advance
RR213 wrote:When configuring the input pins there is the option for active high or active low. For 12v switched inputs use active high.
adrian wrote:The PDM switch inputs were originally designed for pull to ground type switching so unfortunately the only way to wire a 12V switch into the PDM is by adding a pull down resistor.
