by David Ferguson on Sun Nov 08, 2020 12:41 pm
Is the laptop running on batteries? Is the car on a charger? You can have grounding problems in that scenario. Try running the laptop on battery power.
Also, make sure you are using M84 ECU Manager, not ECU Manager which works with M400/M600/M800 ECUs.
Check out Shift RPM - https://shiftrpm.veracitydata.com
