LIN-01 LIN to CAN
LIN-01 LIN to CAN
Postby greenamex2 on Fri Jan 24, 2020 11:20 pm
Hi all
Do you have any details for the "LIN-01 LIN to CAN adapter"?
I believe it is Motec part number 61310 and is for the Bosch wiper motor.
Thanks in advance.
Motec CDL3+M130+LTCD+MDD+PDM15
greenamex2
Re: LIN-01 LIN to CAN
Postby Herrubermensch on Sun Jan 26, 2020 8:14 am
I wish I had known such a beast existed! Would have saved me a ton of rewiring that I did to accommodate the Bosch wiper motor!
--Peter
Herrubermensch
Postby greenamex2 on Mon Jan 27, 2020 6:02 am
Herrubermensch wrote:I wish I had known such a beast existed! Would have saved me a ton of rewiring that I did to accommodate the Bosch wiper motor!
--Peter
Yeah, remember that conversation. I am looking at it because of a lack of IO/money!
greenamex2
Postby greenamex2 on Wed Feb 19, 2020 6:40 pm
Anybody have any details, or is it vapourware?
greenamex2
Postby adrian on Thu Feb 20, 2020 7:41 am
Sorry for the delay, yes P/No 61310 exists and will control the Bosch WDA LIN wiper motor. I have attached a Dash config with the CAN messaging required to make it work and a description of what the channels are below:
WDA Wiper Enable – Must be set to 1 for the motor to work
WDA Wiper Int Mode – Set to 0 for 4.5 second time between wipes when Int is set or 1 for 20 seconds between wipes.
WDA Wiper SST – Set to 1 momentarily for a single wipe
WDA Wiper Int – Set to 1 for Intermittent mode. Time between wipes as per "WDA Wiper Int Mode"
WDA Wiper Spd1 – Set to 1 for continuous wiping at slow speed
WDA Wiper Spd2 – Set to 1 for continuous wiping at high speed
Wiring is as per a KTC, baud rate of CAN is 1Mbit.
Bosch WDA Wiper Motor Templates.c185v61
(863.38 KiB) Downloaded 576 times
Postby greenamex2 on Thu Feb 20, 2020 6:34 pm
Wow...thanks Adrian
Time to review my configuration
Again!
greenamex2
Postby greenamex2 on Fri Feb 21, 2020 7:03 am
lin wda.png (78.73 KiB) Viewed 12532 times
Looks a bit wonky in Dash Manager
greenamex2
Postby adrian on Fri Feb 21, 2020 7:16 am
Looks like you have an old Master channel list. You can either download the latest version of Colour Dash Manager from our website which will update it or copy the below file to C:\Program Files (x86)\MoTeC\Channels and override the existing file.
master.chl
(840.04 KiB) Downloaded 592 times
Postby greenamex2 on Sat Feb 22, 2020 7:14 am
Thanks Adrian, that sorted it.
Not the easiest thing to code on a CDL3 but I have got it.
Back to my config spreadheet!
greenamex2
