Engine Tuning Packages
BMW: 135 (GPR-DI PROPORTIONAL PUMP)
Integration type: Engine Tuning Base ECU
The GPR-DI package has the following features pre-configured to suit this engine
Make: BMW
Model: 135
Model Year: 2007
Target: Car
Engine Variant: N54B30
Fuel: Petrol / Gasoline
Fuel Octane: 98 RON
Injectors: OEM Std.
Cams: OEM Std.
Cylinder head(s): OEM Std.
Exhaust manifold: OEM Std.
Inlet manifold: OEM Std.
Turbo: OEM Std.
Waste gate: OEM Std.
Ignition system: OEM Std.
Coils: OEM Std.
Idle control: OEM Std. DBW
Throttle: OEM Std.
CAN Nodes: LTC/PLM
FORD: COYOTE (GPR)
The GPR package has the following features pre-configured to suit this engine
Make: Ford
Model: Coyote
Model Year: 2011
Target: Car
Engine Variant: Mustang
Fuel Octane: 98 RON
Injectors: OEM Std.
Cams: OEM Std.
Compression: 11:1
Turbo: N/A
Waste gate: N/A
Coils: OEM Std.
Boost control: N/A
Restrictor: N/A
Throttle: OEM Std.
CAN Nodes: LTC/PLM
FORD: MUSTANG (GPR)
Make: Ford
Model: Mustang
Model Year: 2011
Target: Car
Engine Variant: Coyote
Fuel Octane: 98 RON
Injectors: OEM Std.
Cams: OEM Std.
Compression: 11:1
Turbo: N/A
Waste gate: N/A
Coils: OEM Std.
Boost control: N/A
Restrictor: N/A
Throttle: OEM Std.
CAN Nodes: LTC
HONDA: CIVIC TYPE R (GPRP-DI)
The GPRP-DI package has the following features pre-configured to suit this engine
Make: Honda
Model: Civic Type R
Model Year: 2017-20
Target: Car
Engine Variant: K20C
Cam actuators disabled
Fuel Octane: 98 RON
Injectors: OEM Std.
Cams: OEM Std.
Compression: 9.8:1
Turbo: OEM Std.
Coils: OEM Std.
Boost control: Waste gate
Restrictor: N/A
Throttle: OEM Std.
CAN Nodes: LTC
LEXUS: 2UR-GSE
This package has the following features pre-configured to suit the engine
Engine Variant: 2UR-GSE
Year: 2008
Fuel Octane: 98 RON
Injectors: OEM Std.
Cams: OEM Std.
Compression: OEM Std.
Turbo: N/A
Wastegate: N/A
Coils: OEM Std.
Boost control: N/A
Restrictor: N/A
Throttle: OEM Std.
CAN Nodes: N/A
MERCEDES: A45 (GPA-DI, GPR-DI, GPRP-DI)
The following features are pre-configured to suit this engine.
Relevant packages include: GPA-DI, GPR-DI, GPRP-DI
Make: Mercedes AMG
Model: A45
Model Year:
Target: Car
Engine Variant: M133
Fuel Octane: 98 RON
Injectors: OEM Std.
Cams: OEM Std.
Turbo: OEM Std.
Wastegate: OEM Std.
Coils: OEM Std.
Boost control: Wastegate
Restrictor: N/A
Throttle: OEM Std.
CAN Nodes: LTC, EPS
Make: Mercedes AMG
Model: A45
Model Year:
Target: Car
Fuel Octane: 98 RON
Injectors: OEM Std.
Cams: OEM Std.
Turbo: OEM Std.
Wastegate: OEM Std.
Coils: OEM Std.
Restrictor: N/A
Throttle: OEM Std.
CAN Nodes: LTC, EPS
MINI: COOPER S (GPR-DI PROPORTIONAL PUMP)
Make: BMW
Model: Mini
Model Year: 2008
Target: Car
Engine Variant: N14B16
Fuel Octane: 98 RON
Injectors: OEM Std.
Cams: OEM Std.
Turbo: N/A.
Wastegate: N/A.
Coils: OEM Std.
Boost control: N/A
Restrictor: N/A
Throttle: OEM Std.
CAN Nodes: LTC
Make: BMW
Model: Mini
Model Year: 2008
Target: Car
Fuel Octane: 98 RON
Injectors: OEM Std.
Cams: OEM Std.
Turbo: N/A.
Wastegate: N/A.
Coils: OEM Std.
Boost control: N/A
Restrictor: N/A
Throttle: OEM Std.
CAN Nodes: LTC
NISSAN: SR20-DET (GPR)
Make: Nissan
Model: SR20-DET
Model Years: 1991-1994
Target: Car
Engine Variant: S13 Turbo
Fuel: E85
Fuel Octane: 105 RON
Injectors: ID1000
Cams: OEM Std.
Compression: 8.75:1
Turbo: GT28
Waste gate: Internal GT28
Ignition system: CDI 4 Channel 41011
Coils: Mercury CDI Coils 42024
Idle control: OEM Std. PWM valve
Boost control: MAC 35A-AAA-DDBA-1BA
Restrictor: 36mm
Throttle: OEM Std.
CAN Nodes: LTC/PLM
SUBARU: IMPREZZA WRX STI (GPA)
The GPA package has the following features pre-configured to suit this engine
Make: Subaru
Model: Impreza WRX STi
Model Year: 1996
Target: Car
Engine Variant: Type RA STi Version 2 V-Limited
Fuel Octane: 98 RON
Injectors: SARD 6304D.1.0 OEM Std.
Cams: OEM Std.
Compression: 8.5:1
Turbo: Mitsubishi TD05H OEM Std.
Waste gate: Internal TD05H OEM Std.
Coils: OEM Std.
Boost control: OEM Std.
Restrictor: N/A
Throttle: OEM Std.
CAN Nodes: LTCN
TOYOTA: HILUX 1KD-FTV 2012-15 (GPR DIESEL EXTERNAL DRIVE)
The GPR Diesel package has features pre-configured to suit this engine
TOYOTA: HILUX 1VD-FTV 2007-17 (GPR DIESEL EXTERNAL DRIVE)
FORD: COYOTE (GPR)
FORD: MUSTANG (GPR)
LEXUS: 2UR-GSE
