Lamborghini Huracan 2014 M1 Kit
Part No: #11407
This Plug-In Kit provides a complete replacement for the factory OE (original equipment) ECUs for the Lamborghini Huracan or Audi R8 engine. Using existing wiring, the original fuel system and sensors, it delivers convenient installation with fully programmable control.
Two M142 ECUs are supplied, one acting as a Master ECU, in which all common tuning adjustments are made, the other as a Slave ECU that takes commands from the Master, together providing full functionality plus Engine Torque Control and additional features unique to these vehicles.
Along with fuel, ignition, throttle and camshaft control, this kit also supports other OE ECU features, including:
  • Push button start
  • 7-Speed DSG transmission integration with tunable shift cuts and blips
  • Direct injector with high pressure fuel pump control, and secondary port injector control.
  • Optional boost control via wastegate solenoids or servos
  • Air conditioner control
  • Variable speed fan control
  • Map switching from driving modes (Strada, Sport, Corsa) and from cruise control buttons / stalk
  • Fuel lift pump and coolant pump control
  • Cruise control
  • Integrated electronics for OE Lambda sensors
  • All OE dash functionality including warnings
The Package contains the base calibration and all settings for the sensors, direct fuel injectors, port fuel injectors, ignition coils, knock control, throttle servos and camshafts. They have also been calibrated to match the OE factory fuelling, ignition and camshaft phasing. This saves a significant amount of time by shortcutting the setup process. Users can begin tuning to their desired power level right away with the assurance of a safe base tune that is equivalent to the original vehicle.
Included are many ancillary features commonly found on race cars, such as anti-lag, driver switches (e.g. pit switch, launch enable, boost trim), gearbox control, knock control, intercooler sprays, launch control, coolant pumps and traction control.
The product fully integrates with other MoTeC devices, providing pre-defined CAN messaging for all current Displays/Loggers, LTCs, E888, Video Capture Systems, GPS, ADR, BR2, PDMs and SLMs.
KIT CONTENTS
Hardware
  • 13142 - M142 ECU x 2
  • 61432 - M142 LAMBORGH HURACAN 2014 ADAPTOR KIT
    • 61404 - M1 ADAPTOR 250MM 26W KEY 1 STUB LOOM x 2
    • 61405 - M1 ADAPTOR 250MM 26W KEY 3 STUB LOOM x 2
    • 61406 - M1 ADAPTOR 250MM 34W KEY 1 STUB LOOM x 2
    • 61407 - M1 ADAPTOR 250MM 34W KEY 2 STUB LOOM x 2
    • 61433 - M142 LAMBO HURACAN 2014 BREAKOUT LOOM
    • 61434 - M142 LAMBO HURACAN 2014 ADAPT MASTER BOX
    • 61436 - M142 LAMBO HURACAN 2014 ADAPT SLAVE BOX
Licence
  • 23390 – M1 LIC - LAMBORGHINI HURACAN 2014 MASTER
  • 23391 – M1 LIC - LAMBORGHINI HURACAN 2014 SLAVE
These Licences are required to run the Lamborghini Huracan 2014 Master and Slave M1 Packages in the M142 ECUs.
VEHICLE COMPATIBILITY
This product includes CAN messaging for full OE vehicle integration. The Package caters for OE vehicle systems such as power steering, ABS, starting systems and dashboards.
The following table shows compatible vehicles.
Vehicle Year starting Badge Comment
Lamborghini Huracan 2014 LP610-4 Including Spyder
Lamborghini Huracan 2017 LP640-4 Performante Including Spyder
Lamborghini Huracan 2016 LP580-2 Rear wheel drive. Including Spyder.
Lamborghini Huracan 2019 EVO AWD, RWD and Spyder
Lamborghini Huracan 2021 STO Rear wheel drive
Audi R8 2015 (no badge) Including Spyder
Audi R8 2016 V10 Plus Including Spyder
Audi R8 2017 RWS Rear wheel drive. Including Spyder.
Audi R8 2018 LMS GT4 Rear wheel drive
New models will be added to the list once testing is complete. Contact MoTeC if your model is not on the list.
This product is not suitable for Audi R8 2008-2015 (first generation) models.
FEATURES
  • M142 ECU hardware, two ECUs configured as Master and Slave, combined -
    • 64 outputs
    • 90 inputs
    • 6 x CAN, 2 x RS232, 2 x LIN, 2 x Ethernet
  • Traction control
    • Controls front to rear wheel slip closed loop to an aim value.
    • Torque reduction by throttle control, ignition timing or cut for fast response.
    • Tunable and dynamically adjustable aim slip.
  • Traction Model system
    • Controls the maximum wheel torque via throttle reduction.
    • Dynamically adjustable for downforce and G force (lateral and vertical).
    • This open loop system works in conjunction with the closed loop slip based control.
  • Flex Fuel and Dual Fuel control
    • Model based fuel type selection, reduces tuning time.
    • Comprehensive tunability.
    • Ethanol sensor support.
  • Boost dual control
    • Two separate closed loop control systems with respective boost control solenoid outputs and boost pressure sensors.
    • Comprehensive tuning including influences for barometric pressure and gear.
    • Allows for multiple intercooler configurations including water-to-air with pump and fan control.
    • Integrates with torque control system.
  • Nitrous control
    • For wet or dry nitrous oxide systems.
    • Two stage with multiple trigger conditions and time limits.
    • Nitrous transport delay for dry systems.
    • Fuel pump triggers.
  • Boost Servo control
    • Controls dual servo operated wastegates or blow-off valves.
    • Multiple sources for aim position.
    • Use for boost control, blow-off valve or turbo surge prevention.
  • Gear Up Shift Torque reduction
    • Fully tunable gear shift torque reduction amount based on current torque and clutch slip.
    • Ignition retard and/or ignition/fuel cut methods.
    • Integrates with TCM based torque reduction control.
  • Clutch Slip control
    • Reduce torque by throttle control to protect the clutch from damage (overheat).
    • Reduce torque by ignition retard, closed loop to an aim slip, which allows safe operation to the limits of the clutch.
  • Knock control system
    • Engine knock detected by DSP to filter out noise.
    • Individual cylinder control; only act on the cylinder that is knocking.
    • Control successive knock events by:
      • Reducing ignition timing
      • Adding fuel
      • Adding ignition cut
    • Control filtering based on single event, transient conditions or gear shift.
  • Launch control
    • Closed loop engine speed control using ignition timing and cut.
    • Builds boost without loading the engine, giving very consistent engine speed and torque available for take off.
    • Fast boost building using higher engine speed, reducing to desired launch engine speed as boost rises to the aim pressure.
  • Driver Map switch
    • Multiple toggle, latching or 10 position switch inputs.
    • Link switches to one or multiple subsystem controls.
    • Map switching and/or enable control for useful subsystems, e.g. Throttle Pedal, Traction control, Gear Shift, Anti Lag.
  • Throttle pedal damper, filters the throttle pedal at low opening for improved drive-ability.
  • Warning system
    • Light output and OE check engine lamp.
    • Solid or flashing at 0.5 Hz, 1 Hz or 5 Hz depending on severity of the warning.
    • Threshold limits with time delays all configurable.
    • Warnings for diagnostic conditions and subsystem active.
    • Additional OE telltales, low oil level, coolant hot, and more.
  • Integrated 250 Mb of logging memory.
  • Includes Level 2 Data Logging: 200 channels at up to 200Hz.
    • Upgradable to Level 3 Logging: 2000 channels at up to 1000Hz.
  • Data analysis via MoTeC's renowned i2 software.
  • OE TCM (DSG transmission) integration
    • Obeys commands from the TCM as per OE.
    • Down shift throttle blip with rev matching.
    • Up shift torque reduction by ignition retard and fuel cut.
    • Torque limit for shift blending and transmission limp home.
    • Tunable for take off, shift feel, shift points, launch and more.
  • OE VDC (ABS) integration
    • VDC system operates as per OE.
    • Obeys torque reduction commands for traction control, ESP and limp home (tunable).
    • Reads ABS data, wheel speeds, acceleration lateral and longitudinal, etc.
  • Bosch Motorsport ABS M4 and M5 support.
  • Bosch CAN inertial sensor MM5.10 support.
  • Torque modelling
    • Based on normal engine tuning, e.g. the tuning process is no more difficult or time consuming than tuning an M1 ECU without torque modelling.
    • Limits torque accurately using the throttles, compensates for any boost pressure.
    • Integrates with ignition timing and ignition/fuel cut systems for seamless blending between torque reduction methods.
  • Engine Load (fuelling) calculation from different sources
    • Inlet manifold pressure sensors.
    • Mass air flow sensors.
    • Throttle position and boost pressure.
    • Combination of the above.
  • Cruise Control
    • Functionality exactly like the OE ECU.
    • Set speed adjustable in configurable increments in km/h or mph.
    • Fully tunable control.
    • Speed limiter mode.
    • Preset speed settings.
  • Driver Steering Wheel map switching
    • Displays the setting on the OE dash, overrides the tacho and red line display.
    • Three setting with 10 positions.
    • M button in Corsa mode used for momentary (hold down) functions like rolling launch.
  • Control for 5 separate fuel pumps
    • Multi speed pump control.
    • Sub fuel pump switch control.
    • PWM closed loop fuel pressure control system.
    • Options for many fuel pump and system configurations.
  • Fuel Closed Loop mixture control for individual banks.
  • Fallback and limp home strategies
    • If a sensor fails (e.g. MAP), alternate load sensors are used.
  • Easy wiring of additional sensors via the 'breakout' connector: multiple EGTs (via TCA Thermocouple Amplifier or up to 8 via E888), GPS.
  • Gear Automatic Shift control, allows fully tunable gear shift points.
  • Ignition output pin for each cylinder (coil on plug).
  • Inlet and exhaust camshaft timing control.
  • Dual bank Lambda sensor control with LTC modules fitted inside the ECU adaptor boxes, using OE Lambda sensors.
  • Engine physical settings for fast setup and minor re-tuning for many modifications.
  • Engine pumping efficiency, air flow and load modelling based on inlet manifold pressure.
  • Dual bank fuelling
    • Each bank can be fuelled from its respective set of sensors, MAF, Boost, MAP, TP, AT.
    • Redundant sensor support; if one sensor fails the other bank's sensor is automatically substituted.
  • Sensor calibrations available for many common automotive sensors.
  • Transient fuelling compensation using physical modelling of fuel film remaining in the inlet manifold.
  • Support of MoTeC devices: ADR, E8XX, PDM, SLM, VCS, C1xx dashes.
  • Test settings for most outputs, including injection and ignition outputs, for easier setup.
  • Wastegate Pressure closed loop control, e.g. for CO2 systems.
  • Turbocharger Bypass Valve control (electric blow-off valve).
  • Air Conditioner control
    • Conditional clutch activation.
    • Fan control.
  • Coolant Temperature compensations for engine speed limit, ignition timing, fuel mixture and boost limit.
  • Coolant Pump output with PWM control.
  • Coolant Pump After Run functionality, optionally with additional pump output.
  • Engine Speed Limiting with ignition cut and/or fuel cut.
  • Fuel Flow Supply and Fuel Flow Return sensor inputs.
  • Exhaust Sound control.
  • Charcoal canister purge valve control.
  • GPS data via CAN or RS232.
  • Intercooler Temperature and spray control.
  • Differential Oil Temperature control with dedicated temperature sensor and pump output.
  • Engine Charge air temperature calculation, allows for correction of inlet air temperature (compensation of heat soak effect etc.).
  • Lap distance, time and number via BR2, GPS or switched input, with split and sector options.
  • Race Time system
    • Trim tables for ignition timing, fuel mixture, boost limit and torque limit.
    • Integrates with launch and traction control.
  • Idle control system using ignition timing and throttle control.
  • Engine Load Average, allows trims to be applied with persistent high engine load.
  • Dedicated fuel, ignition and throttle setting for cranking and post start.
  • Alternator closed loop control.
  • Engine hours, odometer and trip meter.
  • Configurable security for multiple users.
  • Brake State configuration using a switch or a pressure sensor.
  • Brake Vacuum system with pump control.
  • ECU internal G-force (acceleration) – longitudinal, lateral and vertical.
  • ECU CAN receive from a defined CAN ID for data reception from MoTeC devices. Support of 3 CAN buses.
  • ECU CAN transmit of the most common channels using standard MoTeC CAN templates, ideal for MoTeC dash displays.
  • Drive by Wire / Throttle Servo dual bank control.
  • Throttle Pedal sensor with translation table commanding engine torque.
  • Transmission Pump output with transmission temperature threshold and hysteresis control.
  • Vehicle Speed measurement using wheel speed sensors, estimation or GPS.
  • Auxiliary Time system with tables for ignition timing compensation, fuel volume trim and fuel mixture aim.
  • Vehicle Pitch control to prevent wheel stands on drag cars.
  • Clutch actual and commanded pressures for logging.
  • Auxiliary Outputs x 5, for PWM control of added actuators:
    • Duty cycle tables using engine speed and throttle or manifold pressure axis.
    • Activation based on inlet manifold pressure or throttle position.
    • Auxiliary Output 1 and 5 include tables for ignition timing compensation, fuel volume trim and fuel mixture aim.
    • Auxiliary Output 5 includes external sensor input.
  • Turbo Speed limiting.
  • Driver Counter Switch allows push buttons to be used as up/down counting for driver switches.
    • Vehicle Yaw, Pitch and Roll rate
    • Airbox Mass Flow, Pressure and Temperature
    • Ambient Temperature
    • Brake Pressure Front and Rear
    • Brake Switch
    • Coolant Pressure and Temperature
    • Engine Oil Pressure and Temperature
    • Engine Crankcase Pressure
    • Exhaust Pressure Bank 1 and Bank 2
    • Exhaust Temperature (EGT) via TCA Thermocouple Amplifier, Generic CAN or E888 for Bank 1 and 2 Collector, and Cylinders 1 to 6.
    • Exhaust Lambda via LTC, LTCN or PLM for Bank 1 and 2 Collector, and Cylinders 1 to 10.
    • Fuel Pressure and Temperature
    • Fuel Tank Level
    • Gear Neutral Switch
    • Gear Shift Request
    • Steering Angle and Pressure
    • Transmission Pressure and Temperature
    • Turbocharger Speed
    • Turbocharger Inlet/Outlet Temperature
    • Turbocharger Wastegate Position
    • G-Force (Acceleration) – Longitudinal, Lateral, Vertical
    • Wheel Speed sensors front/rear left/right, wired or CAN input
    • Auxiliary Fuel Pressure
M142 ECU AND BREAK OUT PINOUT
M142 Connector A - 34 Way
Mating Connector: Tyco Superseal 34 Position Keying 2 (MoTeC #65067)
Pin Designation Full Name Master / Slave Pin* Master / Slave Function*
A01 AT5 Analogue Temperature Input 5 105-39 Oil Pressure Switch / not used
A02 AT6 Analogue Temperature Input 6 E19 Inlet Air Temperature Bank 1 / Bank 2
A03 AV15 Analogue Voltage Input 15
A04 AV16 Analogue Voltage Input 16
A05 AV17 Analogue Voltage Input 17 91-21 Fuel Tank Pressure Sensor / not used
A06 INJ_D1A_NEG Direct Injector 1A - 105-24 Injector 1 Low / Injector 6 Low
A07 INJ_D1A_POS Direct Injector 1A + 105-44 Injector 1 Low / Injector 6 High
A08 INJ_D1B_POS Direct Injector 1B + Injector operation compromised if connected
A09 INJ_D1B_NEG Direct Injector 1B - Injector operation compromised if connected
A10 SEN_5V0_C1 Sensor 5.0V C
A11 LA_NB1 Lambda Narrow Input 1
A12 LA_NB2 Lambda Narrow Input 2
A13 KNOCK3 Knock Input 3 105-101 Knock Sensor 2 / Knock Sensor 4 pin 1
A14 KNOCK4 Knock Input 4 105-80 Knock Sensor 2 / Knock Sensor 4 pin 2
A15 DIG2 Digital Input 2 91-15 Airbox Mass Flow Sensor Bank 1 / Bank 2
A16 DIG3 Digital Input 3 E23 Spare DIG3 Input
A17 DIG4 Digital Input 4 E24 Spare DIG4 Input
A18 SEN_5V0_C2 Sensor 5.0V C
A19 SEN_5V0_B2 Sensor 5.0V B 91-66 Throttle Pedal Tracking 5V / not used
A20 LIN LIN Bus
A21 RS232_RX RS232 Receive E16 GPS Receive (optional)
A22 RS232_TX RS232 Transmit
A23 DIG1 Digital Input 1 105-16 Exhaust Temperature Bank1 / Bank 2
A24 BAT_NEG3 Battery Negative 91-01, 91-02, 91-04 Chassis Ground
A25 BAT_NEG4 Battery Negative 91-01, 91-02, 91-04 Chassis Ground
A26 SEN_0V_C1 Sensor 0V C
A27 SEN_0V_C2 Sensor 0V C
A28 CAN3_HI CAN Bus 3 High 91-60 Inter-ECU CAN High, Internal LTC
A29 CAN3_LO CAN Bus 3 Low 91-77 Inter-ECU CAN Low, Internal LTC
A30 CAN2_HI CAN Bus 2 High 91-79, E28 CAN Powertrain High
A31 CAN2_LO CAN Bus 2 Low 91-80, E27 CAN Powertrain Low
A32 BAT_NEG5 Battery Negative 91-01, 91-02, 91-04 Chassis Ground
A33 SEN_0V_B2 Sensor 0V B
91-45, 91-46, 91-64,
91-69
0V Fuel Tank Pressure, Lift Pressure, Air Temp, Pedal Tracking, Oil Temp, Airbox Mass Flow / 0V Lift Pressure, Air Temp, Airbox Mass Flow
A34 SEN_0V_A2 Sensor 0V A 91-81 0V Pedal Main
* Master and Slave ECU pins and functions are largely the same. Slave pins and functionality is only listed if different from Master pin or functionality.
M142 Connector B - 26 Way
Mating Connector: Tyco Superseal 26 Position Keying 3 (MoTeC #65068)
B01 OUT_HB9 Half Bridge Output 9 91-91 / 105-50 Fuel Pump Control / Piston Cooling Spray Control
B02 OUT_HB10 Half Bridge Output 10 105-8 / 91-73 Coolant Pump Control / Exhaust Flap Control
B03 UDIG8 Universal Digital Input 8 91-48 Crank Request / not used
B04 UDIG9 Universal Digital Input 9 91-51 Starter Solenoid Feedback / not used
B05 UDIG10 Universal Digital Input 10 91-50 Ignition Switch Sense
B06 UDIG11 Universal Digital Input 11 91-30 Brake Switch 2 / not used
B07 UDIG12 Universal Digital Input 12 91-29 Brake Switch 1 / not used
B08 INJ_LS5 Low Side Injector 5 105-32 Port Injector 5 / Port Injector 10
B09 INJ_LS3 Low Side Injector 3 105-6 Port Injector 3 / Port Injector 8
B10 AV9 Analogue Voltage Input 9 E11 Inlet Manifold Pressure Sensor Bank 1 / Bank 2
B11 AV10 Analogue Voltage Input 10 E12 Boost Pressure Sensor Bank 1 / Bank 2
B12 AV11 Analogue Voltage Input 11
B13 BAT_POS Battery Positive 91-3, 91-5, 91-6 Switched Power Source
B14 INJ_LS6 Low Side Injector 6 / E18, 91-71 not used / Brake Vacuum Pump Relay
B15 INJ_LS4 Low Side Injector 4 105-11 Port Injector 4 / Port Injector 9
B16 AV12 Analogue Voltage Input 12
B17 AV13 Analogue Voltage Input 13
B18 AV14 Analogue Voltage Input 14
B19 BAT_POS Battery Positive 91-3, 91-5, 91-6 Switched Power Source
B20 OUT_HB7 Half Bridge Output 7 91-36 / E10, 105-12 Radiator Fan Control Unit 2 / Engine Mount Solenoid Bank 1 and 2
B21 OUT_HB8 Half Bridge Output 8
B22 INJ_D2A_NEG Direct Injector 2A - 105-2 Injector 2 / Injector 7 Low
B23 INJ_D2A_POS Direct Injector 2A + 105-65 Injector 2 / Injector 7 High
B24 INJ_D2B_POS Direct Injector 2B + Injector operation compromised if connected
B25 INJ_D2B_NEG Direct Injector 2B - Injector operation compromised if connected
B26 SEN_5V0_A Sensor 5.0V A 91-83 5V Throttle Pedal Main
M142 Connector C - 34 Way
Mating Connector C: Tyco Superseal 34 Position Keying 1 (MoTeC #65044)
C01 OUT_HB2 Half Bridge Output 2 105-66 Throttle Servo Motor + Bank 1 / Bank 2
C02 SEN_5V0_A Sensor 5.0V A 105-20, 105-41 5V Cam 1,3, Fuel Pressure Direct, Secondary Air Pressure / Cam 2,4, Crank, Secondary Air Pressure
C03 IGN_LS1 Low Side Ignition 1 105-93 Ignition 1 / Ignition 6
C04 IGN_LS2 Low Side Ignition 2 105-94 Ignition 2 / Ignition 8
C05 IGN_LS3 Low Side Ignition 3 105-73 Ignition 3 / Ignition 7
C06 IGN_LS4 Low Side Ignition 4 105-91 Ignition 4 / Ignition 9
C07 IGN_LS5 Low Side Ignition 5 105-72 Ignition 5 / Ignition 10
C08 IGN_LS6 Low Side Ignition 6 105-86 Fuel Pressure Direct Bank 1 Pump A / Bank 2 Pump A
C09 SEN_5V0_B Sensor 5.0V B 105-42 5V Throttle Servo Position Bank 1 / Bank 2
C10 BAT_NEG1 Battery Negative 91-01, 91-02, 91-04 Chassis Ground
C11 BAT_NEG2 Battery Negative 91-01, 91-02, 91-04 Chassis Ground
C12 IGN_LS7 Low Side Ignition 7 91-52, 91-70 / E14 Starter Relay 1, Starter Relay 2 / Gear Shift Up
C13 IGN_LS8 Low Side Ignition 8 91-40 / E15 Air Filter Bypass Solenoid / Gear Shift Down
C14 AV1 Analogue Voltage Input 1 105-103 Throttle Servo Position Sensor - Main Bank 1 / Bank 2
C15 AV2 Analogue Voltage Input 2 105-82 Throttle Servo Position Sensor - Tracking Bank 1 / Bank 2
C16 AV3 Analogue Voltage Input 3 91-82 Throttle Pedal Sensor - Main / not used
C17 AV4 Analogue Voltage Input 4 91-65 Throttle Pedal Sensor - Tracking / not used
C18 OUT_HB1 Half Bridge Output 1 105-88 Throttle Servo Motor - Bank 1 / Bank 2
C19 INJ_D3A_POS Direct Injector 3A + 105-64 Injector 3 High / Injector 8 High
C20 INJ_D3B_POS Direct Injector 3B + Injector operation compromised if connected
C21 INJ_D4A_POS Direct Injector 4A + 105-43 Injector 4 & 5 High / Injector 9 & 10 High
C22 INJ_D4B_POS Direct Injector 4B + Injector operation compromised if connected
C23 INJ_LS1 Low Side Injector 1 105-74 Port Injector 1 / Port Injector 6
C24 INJ_LS2 Low Side Injector 2 105-95 Port Injector 2 / Port Injector 7
C25 AV5 Analogue Voltage Input 5 105-59 Fuel Pressure Direct Bank 1 / Bank 2 Sensor
C26 BAT_POS Battery Positive 91-3, 91-5, 91-6 Switched Power Source
C27 INJ_D3A_NEG Direct Injector 3A - 105-46 Injector 3 Low / Injector 8 Low
C28 INJ_D3B_NEG Direct Injector 3B - Injector operation compromised if connected
C29 INJ_D4A_NEG Direct Injector 4A - 105-23 Injector 4 Low / Injector 9 Low
C30 INJ_D4B_NEG Direct Injector 4B - 105-22 Injector 5 Low / Injector 10 Low
C31 OUT_HB3 Half Bridge Output 3 E34 Turbo Wastegate Solenoid Bank 1 / Bank 2
C32 OUT_HB4 Half Bridge Output 4
91-37 / E17, 91-23,
91-88
Radiator Fan Control Unit 1 / Purge Solenoid Bank 1 and 2
C33 OUT_HB5 Half Bridge Output 5 105-53 Inlet Camshaft Control Solenoid Bank 1 / Bank 2
C34 OUT_HB6 Half Bridge Output 6 105-9 Exhaust Camshaft Control Solenoid Bank 1 / Bank 2
M142 Connector D - 26 Way
Mating Connector D: Tyco Superseal 26 Position Keying 1 (MoTeC #65045)
D01 UDIG1 Universal Digital Input 1 105-18 Crank Reference Position Sensor
D02 UDIG2 Universal Digital Input 2 105-36 Inlet Camshaft Position Sensor Bank 1 / Bank 2
D03 AT1 Analogue Temperature Input 1 105-105 Coolant Temperature Sensor / not used
D04 AT2 Analogue Temperature Input 2 E13 Spare temperature or switch
D05 AT3 Analogue Temperature Input 3 91-11 Airbox Mass Flow Temperature Sensor Bank 1 / Bank 2
D06 AT4 Analogue Temperature Input 4 91-12 Oil Temperature Sensor 2 / not used
D07 KNOCK1 Knock Input 1 105-79 Knock Sensor 1 / Knock Sensor 3 pin 1
D08 UDIG3 Universal Digital Input 3 105-15 Exhaust Camshaft Position Sensor Bank 1 / Bank 2
D09 UDIG4 Universal Digital Input 4 105-13 Engine Oil Level and Temperature Sensor / not used
D10 UDIG5 Universal Digital Input 5 91-17 Park Neutral Switch / not used
D11 UDIG6 Universal Digital Input 6 105-38 Reduced Oil Pressure Switch / not used
D12 BAT_BAK Battery Backup 91-86 Permanent Power
D13 KNOCK2 Knock Input 2 105-100 Knock Sensor 1 / Knock Sensor 3 pin 2
D14 UDIG7 Universal Digital Input 7 91-34 Cruise Cancel Switch / not used
D15 SEN_0V_A Sensor 0V A 105-55, 105-76, 105-97 0V Cam Pos, Fuel Pressure Direct, Secondary Air Pressure, Coolant Temperature / 0V Crank, Cam Pos, Fuel Pressure Direct, Secondary Air Pressure
D16 SEN_0V_B Sensor 0V B 105-102 0V Throttle Servo Position Bank 1 / Bank 2
D17 CAN1_HI CAN Bus 1 High E33 Spare CAN High
D18 CAN1_LO CAN Bus 1 Low E32 Spare CAN Low
D19 SEN_6V3 Sensor 6.3V E3 6.3V Sensor Supply
D20 AV6 Analogue Voltage Input 6 105-104 SecondaryAir Pressure 1 / 2 Sensor
D21 AV7 Analogue Voltage Input 7 Internal Barometric Pressure Sensor Bank 1 Bank 1
D22 AV8 Analogue Voltage Input 8 91-47 Fuel Port Rail Pressure / Fuel Direct Injector Pump Lift Pressure
D23 ETH_TX+ Ethernet Transmit+
D24 ETH_TX- Ethernet Transmit-
D25 ETH_RX+ Ethernet Receive+
D26 ETH_RX- Ethernet Receive-
Breakout Connector E - 34 Way
Mating Connector: Tyco Superseal 34 Position Keying 1 (MoTeC #65044)
Pin Designation Full Name M142 Pin# Function
E01 BAT_POS Battery Positive B13, B19, C26
E02 BAT_POS Battery Positive B13, B19, C26 Boost Solenoid Supply (optional)
E03 SENS_6V3 SEN_6V3 D19
E04 SENS_5V0_B2 Sensor 5.0V B A19 5V Supply MAP Sensor
E05 SENS_5V0_B2 Sensor 5.0V B A19 5V Supply Boost Sensor
E06 SENS_5V0_B2 Sensor 5.0V B A19
E07 SENS_5V0_B2 Sensor 5.0V B A19
E08 BAT_NEG Battery Negative A24, A25, A32, C10, C11
E09 BAT_NEG Battery Negative A24, A25, A32, C10, C11
E10* SHARE_ENGMT Slave ECU Half Bridge Output 7 B20 (Slave ECU Only) Shared wiring between ECUs.
E11 AV9 Analogue Voltage Input 9 B10 MAP Sensor Signal
E12 AV10 Analogue Voltage Input 10 B11 Boost Sensor Signal
E13 AT2 Analogue Temperature Input 2 D04 Spare
E14 PADDLE_UP Slave ECU Low Side Ignition 7 C12 (Slave only) Gear Shift Up (dedicated). Do not connect on Master.
E15 PADDLE_DN Slave ECU Low Side Ignition 8 C13 (Slave only) Gear Shift Down (dedicated). Do not connect on Master.
E16 RS232RX RS232 Receive A21 Usually for GPS.
E17* SHARE_PURGE Slave ECU Half Bridge Output 4 C32 (Slave only) Shared wiring between ECUs
E18* SHARE_BRK_REL Slave ECU Injector Low Side 6 B14 (Slave only) Shared wiring between ECUs
E19 AT6 Analogue Temperature Input 6 A02 Inlet Air Temperature Sensor Signal
E20 SENS_0V_B2 Sensor 0V B D16 0V Inlet Air Temperature Sensor
E21 SENS_0V_B2 Sensor 0V B D16 0V MAP Sensor
E22 SENS_0V_B2 Sensor 0V B D16 0V Boost Sensor
E23 DIG3 Digital Input 3 A16 Spare
E24 DIG4 Digital Input 4 A17 Spare
E25* SHARE_PIST_COOL Slave ECU Half Bridge Output 9 B01 (Slave only) Shared wiring between ECUs
E26* SHARE_EXH_FLAP Slave ECU Half Bridge Output 10 B02 (Slave only) Shared wiring between ECUs
E27 CAN2LO CAN Bus 2 Low A31 OE Powertrain CAN Bus Low
E28 CAN2HI CAN Bus 2 High A30 OE Powertrain CAN Bus High
E29 SENS_0V_B2 Sensor 0V B D16
E30 SENS_0V_B2 Sensor 0V B D16
E31 SENS_0V_B2 Sensor 0V B D16
E32 CAN1LO CAN Bus 1 Low D18 Spare CAN Bus Low
E33 CAN1HI CAN Bus 1 High D17 Spare CAN Bus High
E34 OUT_HB3 Half Bridge Output 3 C31 Boost Solenoid (optional)
* These pins allow sharing of control functions from one ECU to the harness connector of the other ECU. Do not change this wiring.
PACKAGE DOWNLOAD
Download this package from MoTeC Online.
User Manuals & Guides
Name
Version / Part
Published
Download
Name
Version / Part
Published
Download
GPRP Pro Setup and Tuning Guide
23637-23667
Jul 2022
Download
23637-23667
Jul 2022
23637-23667
Jul 2022
Download
M1 Flex Fuel User Guide
Mar 2017
Download
Mar 2017
Mar 2017
Download
M1 To PDM CAN Messaging User Guide
Aug 2017
Download
Aug 2017
Aug 2017
Download
Tech Notes
Name
Version / Part
Published
Download
Name
Version / Part
Published
Download
CTN0035 M1 Lamborghini Huracan 2014 User Guide
Sep 2021
Download
Sep 2021
Sep 2021
Download
CTN0042 Huracan Fuel tank pressure sensor voltage
Jun 2023
Download
Jun 2023
Jun 2023
Download
KIT CONTENTS
FEATURES
PACKAGE DOWNLOAD
