M150 MERCURY V8 450R DEVELOPMENT KIT
Part No: #11509
From a single engine vessel to a multi engine installation, this M150M Plug-in Kit, provides a complete replacement for the OE (original equipment) ECU for the Mercury 450R and 500R V8 outboard engines. The Mercury 4.6L V8 450R. Package includes Level 2 Logging as standard.
For configuration and tuning we recommend using M1 Tune 1.5. Find out more and download Tune 1.5
The kit utilises existing wiring, original fuel system, ignition and sensors, providing convenient installation with fully programmable control, compatible with Mercury dash types.
Along with fuel, ignition, throttle and drive trim control, this Kit also supports other OE ECU features, including;
  • Key Start Via OE CAN
  • Full dash functionality including warnings and run time for maintenance
  • Integration with multi engine boats via CAN
  • Stern Leg Position Monitoring
  • Multi Engine Synchronisation
The supplied start file contains all calibrations and settings for the sensors, port fuel injectors, ignition coils, knock control, throttle servo, cruise control. It has also been calibrated to match the OE factory fuelling and ignition. This saves a significant amount of time as it shortcuts the setup process.
The ECU fully integrates with other MoTeC products and provides pre-defined CAN messaging for all current Display Loggers, Loggers, LTCs, E888, GPS, ADR, BR2, PDM and SLM.
VEHICLE COMPATIBILITY
This product includes CAN messaging for full OE vehicle integration. The Package caters for OE Mercury vessel systems such as power steering, starting systems and dashboards.
Engines Supported
Engine
Four Stroke V8 Mercury 450R Outboard
Four Stroke V8 Mercury 500R Outboard
Dashes Supported
Dash Type Dash Type
Vessel view 502 SC1000
Vessel view 703 Simrad GO Series
VesselView 903
Throttles Supported
Throttle Type
Digital Throttle and Shift (DTS)
Mechanical Cable
KIT CONTENTS
  • 13150M - M150 ECU MARINE
  • 61495 - M150 MERCURY V8 450R DEV ADAPTOR KIT
    • 41212 - IGN4 IGNITION MODULE - 4 CHANNEL
    • 53120 - KNOCK SENSOR (045)
    • 61300J - LTC - LSU LAMBDA TO CAN (250K)
    • 61492 - LOOM - M150 MERCURY V8 450R DEV
    • 61493 - R3 RELAY MODULE
    • 61494 - M150 MERCURY V8 450R DEV MOUNTING KIT
      • 3 x M5 S/S Nylock nuts
      • 3 x M5 S/S flat washers
      • 2 x M3 x 20mm S/S button head screw
      • M8 x 30mm S/S hex bolt
      • ECU mounting bracket
      • IGN4 mounting bracket
Licence
  • 23807 - M1 Licence - Mercury Outboard 112
    This licence includes Level 2 Logging.
This Licence is required to run the Mercury 4.6L V8 450R. Package in the M150M ECU.
OPERATION
Mercury OE Integration
To allow for the M1 ECU to communicate with the other OE modules on the CAN Bus (Dash, Body module, DTS, etc.) The following settings within the Mercury group need to be configured:
  • Mercury Engine Configuration
  • Mercury Engine ID
  • Mercury Dash Type
  • Mercury Dash Tank Configuration
Reference Mode
Package reference mode will be preset for a Mercury 450/500 Outboard engine.
ECU Power
The M1 ECU will be powered when the key is turned to ignition position.
Engine Start
This feature operates identically to OE behaviour.
Driver Switches
Various in boat switches are received over CAN bus and assigned to firmware resources to allow for mode switching or outputting to certain devices on the CAN Bus.
FEATURES
  • Drive Trim Control.
  • Starboard and Port Trim Tab Control.
  • Support of Mercury OE Systems:
    • Dash Warnings supported and enabled through M1 Warning Module.
    • Mercury OE DTS Systems via CAN: Throttle Lever, Crank Request, Gear Position Request, Drive Trim Up and Down Request.
    • Multi Engine Support - Up to 6.
    • Multi Engine Synchronisation.
  • Vehicle Speed measured through using Pitot Tube or Paddle Wheel.
  • Moving Prop Alert warning light output.
  • Propeller Speed Sensor.
  • Reduced ECU Transmit Mode for Integration with vessels that have a 250kbps CAN bus speed.
  • Steering Pump Output.
  • Throttle Limit Decrease Rate table for when a throttle limit is requested for smooth throttle reduction.
  • Fuel Water Content Sensor (Water in Fuel Sensor).
  • Water Inlet Temperature Sensor.
  • Control of Port Injector fuel system.
  • Configurable Ignition Output Pin for each cylinder allows for coil-on-plug or wasted spark and distributor systems.
  • Sensor Calibrations available for many common automotive sensors.
  • Configurable on-board knock for each cylinder with up to 4 assignable knock sensors (Hardware dependent) and selectable centre frequencies.
  • Dual Bank Lambda control is supported requires optional LTC with Bosch LSU4.9 sensor.
  • Physical settings for engine displacement, fuel density + molar mass, stoichiometric ratio and injector characteristics allow for simplified engine start-up prior to tuning.
  • Easy and fast engine tuning using engine efficiency map.
  • Engine load modelling based on inlet manifold pressure and inlet manifold temperature. Alternatively, allows for throttle based load.
  • Engine Charge Temperature calculation, allows for correction of Inlet Air Temperature.
  • Engine speed limiting with ignition cut and/or fuel cut with individual decay rates for smooth power reduction through Engine Speed Limit Decay table.
  • Transient fuelling compensation using physical modelling of fuel film.
  • Nitrous system with one activation stage with fuel and ignition compensations.
  • Test settings for most outputs, including injection and ignition outputs for easier setup.
  • Assisted engine start with dedicated fuel volume and idle compensations during crank and post start.
  • Configurable boost control (using a normal or inverted solenoid output).
  • Coolant temperature compensations for engine speed limit, ignition timing, fuel mixture, boost limit.
  • Engine oil pressure and Temperature.
  • Support for up to 3 fuel pump switched outputs. Activation based on fuel flow demand and nitrous injection.
  • Fuel Flow Supply sensor and Fuel Flow Return sensor.
  • Fuel Tank 1 Level.
  • Fuel Tank 2 Level.
  • Gear Position detection and request.
  • Gear Shift servo supported.
  • Race Time system with trim tables for ignition timing compensation, fuel mixture aim, boost limit, throttle limit and engine boost limit.
  • Idle Closed Loop control system using ignition, drive by wire actuation or idle solenoid.
  • Engine Load Average channel with tables for engine speed limit, ignition timing trim, fuel mixture aim, throttle limit and engine boost limit.
  • Closed Loop Alternator Control.
  • Dual Bank drive by wire throttle servo control.
  • Throttle Lever Sensor with translation table.
  • Use of a Throttle Lever sensor or a Throttle Position sensor in case of a cable throttle.
  • Vehicle Speed Limit Control system (DBW-throttle based).
  • Configurable warning system with light and CAN output.
  • Auxiliary time system with tables for ignition timing compensation, fuel volume trim and fuel mixture aim.
  • Support of 3 M150M CAN buses.
  • ECU CAN Receive from a defined CAN ID for data reception from MoTeC devices.
  • ECU CAN Transmit of the most common channels using standard MoTeC CAN templates.
  • GPS acquisition and logging via CAN and Rs232.
  • Driver Switches.
    • 4 configurable driver switches and 4 rotary switches, each with 10 positions that can be simultaneously mapped to launch control, anti-lag, race time reset, engine speed limit maximum, throttle lever translation, ignition timing, fuel mixture aim and boost limit.
  • Launch control.
  • 5 auxiliary outputs for PWM control of added actuators:
    • Duty Cycle using Engine Speed and Throttle or Manifold Pressure Axis.
    • Activation based on inlet manifold pressure or throttle position.
    • Auxiliary Output 1 includes tables for Ignition Timing Compensation, Fuel Volume Trim and Fuel Mixture Aim.
  • Optional integrations:
      • Boost Pressure.
      • Coolant Pressure and Temperature.
      • Engine Crankcase Pressure.
      • Exhaust Temperature via TCA Thermocouple Amplifier, Generic CAN for Collector, Bank 1 and 2.
      • Fuel Flow and Temperature.
      • Fuel Pressure and Temperature.
      • Steering Angle and Pressure.
INSTALLATION
See below in the "Downloads" section for an "Installation Guide".
PINOUT
M150M Connector A - 34 way
Mating Connector: Tyco Superseal 34 Position Keying 2 – MoTeC #65067
Pin Number Designation Full Name OE Pin Function
A01 AT5 Analogue Temperature Input 5
A02 AT6 Analogue Temperature Input 6
A03 AV15 Analogue Voltage Input 15
A04 AV16 Analogue Voltage Input 16
A05 AV17 Analogue Voltage Input 17
A06 IGN_LS9 Low Side Ignition 9
A07 IGN_LS10 Low Side Ignition 10
A08 IGN_LS11 Low Side Ignition 11
A09 IGN_LS12 Low Side Ignition 12
A10 SEN_5V0_C1 Sensor 5.0V C 46C - F2 Sensor 5V Supply
A11 LA_NB1 Lambda Narrow Input 1
A12 LA_NB2 Lambda Narrow Input 2
A13 KNOCK3 Knock Input 3/Differential Knock Input 2. Positive
A14 KNOCK4 Knock Input 4/Differential Knock Input 2. Negative
A15 DIG2 Digital Input 2
A16 DIG3 Digital Input 3
A17 DIG4 Digital Input 4
A18 SEN_5V0_C2 Sensor 5.0V C 46C - E4 Sensor 5V Supply
A19 SEN_5V0_B2 Sensor 5.0V B 46C - F1 Sensor 5V Supply
A20 LIN LIN Bus
A21 RS232_RX RS232 Receive DTM4P-1 GPS Serial Port (GPS)
A22 RS232_TX RS232 Transmit
A23 DIG1 Digital Input 1
A24 BAT_NEG3 Battery Negative 50C - G2 ECU Ground
A25 BAT_NEG4 Battery Negative
A26 SEN_0V_C1 Sensor 0V C 46C - E2 Sensor 0V Supply
A27 SEN_0V_C2 Sensor 0V C DTM4P-2 Sensor 0V Supply (GPS)
A28 CAN3_HI CAN Bus 3 High 47B-F2 CAN V 250Kbit/sec
A29 CAN3_LO CAN Bus 3 Low 47B-F1 CAN V 250Kbit/sec
A30 CAN2_HI CAN Bus 2 High 47B - H2 CAN X (Body) 250Kbit/sec
A31 CAN2_LO CAN Bus 2 Low 47B - H1 CAN X (Body) 250Kbit/sec
A32 BAT_NEG3 Battery Negative DTM6P-5&6 Ground (R3 Relay Module /IGN4)
A33 SEN_0V_B1 Sensor 0V B 50C - E3 Sensor 0V Supply
A34 SEN_0V_A1 Sensor 0V A 50C - E1 Sensor 0V Supply
M150M Connector B - 26 way
Mating Connector: Tyco Superseal 26 Position Keying 3 – MoTeC #65068
B01 OUT_HB9 Half Bridge Output 9/Bridge Output 5.Negative
B02 OUT_HB10 Half Bridge Output 10/Bridge Output 5.Positive
B03 UDIG8 Universal Digital Input 8 47B - D4 Fuel Water Content Sensor
B04 UDIG9 Universal Digital Input 9
B05 UDIG10 Universal Digital Input 10 47B - G3
B06 UDIG11 Universal Digital Input 11
B07 UDIG12 Universal Digital Input 12 1A - G1 Propeller Moving Light
B08 INJ_LS5 Low Side Injector 5
B09 INJ_LS3 Low Side Injector 3
B10 AV9 Analogue Voltage Input 9
B11 AV10 Analogue Voltage Input 10 47B - C2 Vehicle Drive Trim Position Sensor
B12 AV11 Analogue Voltage Input 11
B13 BAT_POS1 Battery Positive 46C - G3 ECU Power Relay
B14 INJ_LS6 Low Side Injector 6
B15 INJ_LS4 Low Side Injector 4
B16 AV12 Analogue Voltage Input 12 46C- B4 Coolant (Block) Pressure Sensor
B17 AV13 Analogue Voltage Input 13
B18 AV14 Analogue Voltage Input 14
B19 BAT_POS2 Battery Positive
B20 OUT_HB7 Half Bridge Output 7/Bridge Output 4.Negative
B21 OUT_HB8 Half Bridge Output 8/Bridge Output 4.Positive
B22 INJ_PH9 Peak Hold Injector 9
B23 INJ_PH10 Peak Hold Injector 10
B24 INJ_PH11 Peak Hold Injector 11
B25 INJ_PH12 Peak Hold Injector 12
B26 SEN_5V0_A1 Sensor 5.0V A DTM4P-4 Sensor 5V Supply (GPS)
M150M Connector C - 34 way
C01 OUT_HB2 Half Bridge Output 2/Bridge Output 1.Positive 46C - H2 Throttle Servo Bank 1 Motor
C02 SEN_5V0_A2 Sensor 5.0V A Sensor 5V Supply
C03 IGN_LS1 Low Side Ignition 1 DTM6P-1 Ignition Cylinder 1 & 4 (IGN4)
C04 IGN_LS2 Low Side Ignition 2 DTM6P-2 Ignition Cylinder 2 & 5 (IGN4)
C05 IGN_LS3 Low Side Ignition 3 DTM6P-3 Ignition Cylinder 6 & 7 (IGN4)
C06 IGN_LS4 Low Side Ignition 4 DTM6P-4 Ignition Cylinder 3 & 8 (IGN4)
C07 IGN_LS5 Low Side Ignition 5 1A - B4 Fuel Pump
C08 IGN_LS6 Low Side Ignition 6
C09 SEN_5V0_B Sensor 5.0V B Sensor 5V Supply
C10 BAT_NEG4 Battery Negative 1A - G3 ECU & LTC Ground
C11 BAT_NEG5 Battery Negative 46C - G1 ECU Ground
C12 IGN_LS7 Low Side Ignition 7 1A - E2 Engine Start Motor Relay
C13 IGN_LS8 Low Side Ignition 8 1A - A3 Vehicle Drive Trim Up Actuator
C14 AV1 Analogue Voltage Input 1 47B - J2 Throttle Servo Bank 1 Position Sensor Tracking
C15 AV2 Analogue Voltage Input 2 47B - J4 Throttle Servo Bank 1 Position Sensor Main
C16 AV3 Analogue Voltage Input 3 46C - A1 Engine Oil Pressure Sensor
C17 AV4 Analogue Voltage Input 4 46C - D2 Inlet Manifold Pressure Sensor
C18 OUT_HB1 Half Bridge Output 1/Bridge Output 1.Negative 46C - H1 Throttle Servo Bank 1 Motor
C19 INJ_PH1 Peak Hold Injector 1 1A - F3 Fuel Cylinder 1 Primary
C20 INJ_PH2 Peak Hold Injector 2 1A - D1 Fuel Cylinder 2 Primary
C21 INJ_PH3 Peak Hold Injector 3 1A - F4 Fuel Cylinder 3 Primary
C22 INJ_PH4 Peak Hold Injector 4 1A - F1 Fuel Cylinder 4 Primary
C23 INJ_LS1 Low Side Injector 1 47B - M4 Vehicle Drive Trim Down Actuator
C24 INJ_LS2 Low Side Injector 2 1A - G4 Auxiliary Output 1 (Power Steering)
C25 AV5 Analogue Voltage Input 5 47B - K1 Gear Position Sensor Main
C26 BAT_POS3 Battery Positive 46C - G4 ECU & LTC Power
C27 INJ_PH5 Peak Hold Injector 5 1A - E1 Fuel Cylinder 5 Primary
C28 INJ_PH6 Peak Hold Injector 6 1A - F2 Fuel Cylinder 6 Primary
C29 INJ_PH7 Peak Hold Injector 7 1A - C1 Fuel Cylinder 7 Primary
C30 INJ_PH8 Peak Hold Injector 8 1A - B1 Fuel Cylinder 8 Primary
C31 OUT_HB3 Half Bridge Output 3/Bridge Output 2. Negative 46C - H3 Gear Shift Servo Motor
C32 OUT_HB4 Half Bridge Output 4/Bridge Output 2. Positive 46C - H4 Gear Shift Servo Motor
C33 OUT_HB5 Half Bridge Output 5/Bridge Output 3.Negative 46C - F4 Boost Solenoid Normal
C34 OUT_HB6 Half Bridge Output 6/Bridge Output 3. Positive
M150M Connector D — 26 way
Mating Connector: Tyco Superseal 26 Position Keying 1 – MoTeC #65045
D01 UDIG1 Universal Digital Input 1 1A - C4 Engine Speed Reference
D02 UDIG2 Universal Digital Input 2 47B - K4 Engine Synchronisation Position
D03 AT1 Analogue Temperature Input 1 47B - E2 Coolant (Block) Temperature Sensor
D04 AT2 Analogue Temperature Input 2 47B - L2 Inlet Air Temperature Sensor
D05 AT3 Analogue Temperature Input 3 46C - B1 Engine Oil Temperature Sensor
D06 AT4 Analogue Temperature Input 4 47B - E1 Exhaust Temperature Collector Sensor
D07 KNOCK1 Knock Input 1/Differential Knock Input 1.Positive Knock
D08 UDIG3 Universal Digital Input 3 47B - E4 Vehicle Speed Paddle Wheel Sensor
D09 UDIG4 Universal Digital Input 4 1A - D3 Engine Run Switch
D10 UDIG5 Universal Digital Input 5 46C - C2 Vehicle Drive Trim Up Request Switch
D11 UDIG6 Universal Digital Input 6 46C - C3 Vehicle Drive Trim Down Request Switch
D12 BAT_BAK Battery Backup
D13 KNOCK2 Knock Input 2/Differential Knock Input 1. Negative Knock
D14 UDIG7 Universal Digital Input 7
D15 SEN_0V_A Sensor 0V A
D16 SEN_0V_B Sensor 0V B 1A - D4 Sensor 0V Supply
D17 CAN1_HI CAN Bus 1 High 47B - G2 CAN P (Dash & LTC) 250Kbit/sec
D18 CAN1_LO CAN Bus 1 Low 47B - G1 CAN P (Dash & LTC) 250Kbit/sec
D19 SEN_6V3 Sensor 6.3V
D20 AV6 Analogue Voltage Input 6 47B - C1 Gear Position Sensor Tracking
D21 AV7 Analogue Voltage Input 7
D22 AV8 Analogue Voltage Input 8 47B - D3 Fuel Pressure Sensor
D23 ETH_TX+ Ethernet Transmit+ Ethernet Green/White PC Communications
D24 ETH_TX- Ethernet Transmit- Ethernet Green PC Communications
D25 ETH_RX+ Ethernet Receive+ Ethernet Orange/White PC Communications
D26 ETH_RX- Ethernet Receive- Ethernet PC Communications
Installation Guides
Name
Version / Part
Published
Download
Name
Version / Part
Published
Download
11509
Dec 2024
Download
11509
Dec 2024
11509
Dec 2024
Download
KIT CONTENTS
OPERATION
FEATURES
INSTALLATION
PINOUT
PACKAGE DOWNLOAD
