MCM112 V6 Plug-In ECU Kit
Part No: #12102
The MCM112 ECU kit provides everything required for a complete replacement of the factory ECU on a range of Mercury outboard engines. The kit includes a knock sensor and knock control system, offering a significant advantage over the factory ECU.
The all-in-one ECU and adaptor unit installs quickly and easily, enabling total and instant control of all tuning parameters within minutes. Fine tune your engine for maximum power and economy or add modifications, such as Injectors, Supercharger Pulleys, NOS and Fuel Changes.
The MCM112 integrates with Mercury dash and throttle systems* and seamlessly connects with MoTeC Displays and other MoTeC accessories. It utilises the existing wiring, fuel system, ignition and sensors** and is equally suited to single or multi-engine installations.
Along with fuel, ignition, throttle and drive trim control, this kit also supports other OE ECU features, including;
  • Key Start Via OE CAN
  • Full dash functionality including warnings and run time for maintenance
  • Integration with multi engine boats via CAN
  • Stern Leg Position Monitoring
  • Multi Engine Synchronisation
The supplied start file contains all calibrations and settings for the sensors, port fuel injectors, ignition coils, knock control, throttle servo and cruise control. It has also been calibrated to match the OE factory fuelling and ignition. This saves a significant amount of time as it shortcuts the setup process.
The ECU fully integrates with other MoTeC products and provides pre-defined CAN messaging for all current Display Loggers, Loggers, LTCs, GPS and BR2.
The MCM112 Plug-In ECU Kit Package includes Level 2 Logging as standard.
For configuration and tuning M1 Tune 1.5 must be used (version 1.5.0.0424 or later). Find out more and download Tune 1.5
*Not compatible with Mercury Joystick control and the independent steering Skyhook feature.
**Humidity Sensor not supported.
For further information on the MCM112 ECU Click here
VEHICLE COMPATIBILITY
This product includes CAN messaging for full OE vehicle integration. The Package caters for OE Mercury vessel systems such as power steering, starting systems and dashboards.
V6 Outboard Engines Supported
Description Engine type Induction Capacity
Mercury 175 Outboard Four Stroke V6 NA 3.4L
Mercury 200 Outboard Four Stroke V6 NA 3.4L
Mercury 225 Outboard Four Stroke V6 NA 3.4L
V8 engines are supported with the MCM112 Plug-In ECU Kit 12101
Dashes Supported
Dash Type Dash Type
Vessel view 502 SC1000
Vessel view 703 Simrad GO Series
Vessel View 903
Throttles Supported
Throttle Type
Digital Throttle and Shift (DTS)
Mechanical Cable
KIT CONTENTS
  • 12102 - MCM112 MERCURY V6 ECU KIT
    • 13210 - MCM112 ECU
    • 53120 - KNOCK SENSOR (045)
    • 61621 - LOOM- KNOCK SENSOR (045) EXTENSION
    • 61490 - LOOM- MCM112 EXPANSION
    • 61620 - MCM112 MERCURY V6 MOUNTING KIT
      • 3 x MOUNTING BUSH MCM112
      • 3 x MOUNTING GROMMET MCM112
      • 1 x M6 X 40mm HEX BOLT S/S
      • 1 x M6 S/S FLAT WASHER
      • 1 x KNOCK SENSOR MOUNTING SPACER
Licence
  • 23819 - M1 Licence - To fit Mercury Outboard 112 (MCM112)
    This licence includes Level 2 Logging.
This Licence is necessary to run the required Package in the MCM112 ECU.
OPERATION
Mercury OE Integration
To allow for the ECU to communicate with the other OE modules on the CAN Bus (Dash, Body module, DTS, etc.) The following settings within the Mercury group need to be configured:
  • Mercury Engine Configuration
  • Mercury Engine ID
  • Mercury Dash Type
  • Mercury Dash Tank Configuration
Reference Mode
Package reference mode will be preset for a Mercury 450/500 Outboard engine.
ECU Sleep Mode
  • Battery Connection
    • When the ECU is connected to constant battery power. E.g. the battery is connected, or the battery isolator switch is turned ON the ECU will remain ON for 30 seconds then go into sleep mode.
    • This cycle will repeat anytime battery power is disconnected/reconnected.
    • If M1 Tune is connected to the ECU within the 30 seconds the ECU will remain powered until M1 Tune is disconnected.
  • Ignition ON
    • When the ignition is turned ON then OFF the ECU will remain ON for 5 seconds then go into sleep mode.
    • This cycle will repeat anytime the ignition is turned ON / OFF.
    • If M1 Tune is connected to the ECU with the ignition ON the ECU will remain powered until M1 Tune is disconnected.
Power Hold Relay
This system will keep the ECU powered up whilst connected to M1 Tune after the ignition has been turned OFF.
Cowl Trim Switches
The cowl trim switches will operate while the ECU is in sleep mode (identically to the OE behaviour).
Engine Start
This feature operates identically to OE behaviour.
Driver Switches
Various in boat switches are received over CAN bus and assigned to firmware resources to allow for mode switching or outputting to certain devices on the CAN Bus.
FEATURES
  • Drive Trim Control.
  • Starboard and Port Trim Tab Control.
  • Support of Mercury OE Systems:
    • Dash Warnings supported and enabled through M1 Warning Module.
    • Mercury OE DTS Systems via CAN: Throttle Lever, Crank Request, Gear Position Request, Drive Trim Up and Down Request.
    • Multi Engine Support - Up to 6.
    • Multi Engine Synchronisation.
  • Vehicle Speed measured through using Pitot Tube, Paddle Wheel or optional GPS.
  • Moving Prop Alert warning light output.
  • Propeller Speed Sensor.
  • Reduced ECU Transmit Mode for Integration with vessels that have a 250kbps CAN bus speed.
  • Steering Pump Output.
  • Throttle Limit Decrease Rate table for when a throttle limit is requested for smooth throttle reduction.
  • Fuel Water Content Sensor (Water in Fuel Sensor).
  • Water Inlet Temperature Sensor.
  • Control of Port Injector fuel system.
  • Configurable Ignition Output Pin for wasted spark and distributor systems.
  • Sensor Calibrations available for many common automotive sensors.
  • Configurable on-board knock for each cylinder with up to 2 assignable knock sensors and selectable centre frequencies.
  • Onboard lambda control utilising factory lambda sensor.
  • Physical settings for engine displacement, fuel density + molar mass, stoichiometric ratio and injector characteristics allow for simplified engine start-up prior to tuning.
  • Easy and fast engine tuning using engine efficiency map.
  • Engine load modelling based on inlet manifold pressure and inlet manifold temperature. Alternatively, allows for throttle based load.
  • Engine Charge Temperature calculation, allows for correction of Inlet Air Temperature.
  • Engine speed limiting with ignition cut and/or fuel cut with individual decay rates for smooth power reduction through Engine Speed Limit Decay table.
  • Switchable engine speed limiting feature via throttle control.
  • Transient fuelling compensation using physical modelling of fuel film.
  • Nitrous system with one activation stage with fuel and ignition compensations.
  • Test settings for most outputs, including injection and ignition outputs for easier setup.
  • Assisted engine start with dedicated fuel volume and idle compensations during crank and post start.
  • Configurable boost control (using a normal or inverted solenoid output).
  • Coolant temperature compensations for engine speed limit, ignition timing, fuel mixture, boost limit.
  • Engine oil pressure and Temperature.
  • Fuel Pump priming and control based on engine rotation.
  • Fuel Flow Supply sensor and Fuel Flow Return sensor.
  • Fuel Tank 1 Level.
  • Fuel Tank 2 Level.
  • Gear Position detection and request.
  • Gear Shift servo supported.
  • Race Time system with trim tables for ignition timing compensation, fuel mixture aim, boost limit, throttle limit and engine boost limit.
  • Idle Closed Loop control system using ignition and drive by wire actuation.
  • Engine Load Average channel with tables for engine speed limit, ignition timing trim, fuel mixture aim, throttle limit and engine boost limit.
  • Dual Bank drive by wire throttle servo control.
  • Throttle Lever Sensor with translation table.
  • Use of a Throttle Lever sensor or a Throttle Position sensor in case of a cable throttle.
  • Vehicle Speed Limit Control system (DBW-throttle based).
  • Configurable warning system with light and CAN output.
  • Auxiliary time system with tables for ignition timing compensation, fuel volume trim and fuel mixture aim.
  • Support of 4 CAN buses.
  • ECU CAN Receive from a defined CAN ID for data reception from MoTeC devices.
  • ECU CAN Transmit of the most common channels using standard MoTeC CAN templates.
  • GPS acquisition and logging via CAN and RS232.
  • Driver Switches.
    • 8 configurable driver switches and 4 rotary switches, each with 10 positions that can be simultaneously mapped to launch control, anti-lag, race time reset, engine speed limit maximum, throttle lever translation, ignition timing, fuel mixture aim and boost limit.
  • Launch control.
  • 5 auxiliary outputs for PWM control of added actuators:
    • Duty Cycle using Engine Speed and Throttle or Manifold Pressure Axis.
    • Activation based on inlet manifold pressure or throttle position.
    • Auxiliary Output 1 includes tables for Ignition Timing Compensation, Fuel Volume Trim and Fuel Mixture Aim.
  • Optional integrations:
      • Boost Pressure.
      • Coolant Pressure and Temperature.
      • Engine Crankcase Pressure.
      • Exhaust Temperature via TCA Thermocouple Amplifier, Generic CAN for Collector.
      • Fuel Flow and Temperature.
      • Fuel Pressure and Temperature.
      • Steering Angle and Pressure.
      • Ambient Pressure.
      • Engine Oil Temperature, Pressure and Level.
      • Vehicle Acceleration.
INSTALLATION GUIDE
See below in the "Downloads" section for an "Installation Guide".
PINOUT
MCM112 Connector A - BK (Black)
Pin Number Designation Full Name Function
BK_A1 OUT_LS1 Low Side Output 1
BK_A2 OUT_LS_STB1 Standby Low Side Output 1 ECU Power Relay Out
BK_A3 OUT_LS_STB2 Standby Low Side Output 2 Veh Drive Trim Up Act Out
BK_A4 OUT_LS2 Low Side Output 2
BK_B1 OUT_INJ8 Injector Output 8 Fuel Cyl 8 Prim Out
BK_B4 OUT_LS3 Low Side Output 3 Fuel Pump Out
BK_C1 OUT_INJ7 Injector Output 7 Fuel Cyl 7 Prim Out
BK_C4 IN_DE1 Enhanced Digital Input 1 Eng Speed Ref
BK_D1 OUT_INJ2 Injector Output 2 Fuel Cyl 2 Prim Out
BK_D3 IN_AD1 Analogue Digital Input 1 Lanyard SW
BK_D4 SEN_0V_D Sensor 0V D
BK_E1 OUT_INJ5 Injector Output 5 Fuel Cyl 5 Prim Out
BK_E2 OUT_LS4 Low Side Output 4 Eng Start Motor Relay Out
BK_F1 OUT_INJ4 Injector Output 4 Fuel Cyl 4 Prim Out
BK_F2 OUT_INJ6 Injector Output 6 Fuel Cyl 6 Prim Out
BK_F3 OUT_INJ1 Injector Output 1 Fuel Cyl 1 Prim Out
BK_F4 OUT_INJ3 Injector Output 3 Fuel Cyl 3 Prim Out
BK_G1 OUT_LS5 Low Side Output 5
BK_G2 IN_DE2 Enhanced Digital Input 2
BK_G3 GND Ground
BK_G4 OUT_LS6 Low Side Output 6 Steering Pump Out
BK_H1 OUT_IGN1 Ignition Output 1 Ign Cyl 3 Out
BK_H2 OUT_IGN2 Ignition Output 2 Ign Cyl 6 Out
BK_H3 OUT_IGN3 Ignition Output 3 Ign Cyl 2 Out
BK_H4 OUT_IGN4 Ignition Output 4 Ign Cyl 1 Out
MCM112 Connector B - BN (Brown)
BN_B1 OUT_AC1_C Analogue Current Output 1.Current Exh Lambda Collector Sensor
BN_B2 OUT_AC1_V Analogue Current Output 1.Voltage Exh Lambda Collector Sensor
BN_B3 SEN_0V_E Sensor 0V E
BN_C1 IN_A1 Analogue Input 1 Gear Posn Sensor Tracking Volt
BN_C2 IN_A2 Analogue Input 2 Veh Drive Trim Posn Sensor Volt
BN_C3 IN_AL1 Analogue Lambda Input 1 Exh Lambda Collector Sensor
BN_D1 IN_A3 Analogue Input 3
BN_D2 IN_ADU5 Analogue Digital Pullup 5
BN_D3 IN_A4 Analogue Input 4 Fuel Pres Sensor Volt
BN_D4 IN_ADU2 Analogue Digital Pullup 2 Fuel Water Content Sw
BN_E1 IN_ADU4 Analogue Digital Pullup 4 Exh Temp Collector Sensor Volt
BN_E2 IN_ADU3 Analogue Digital Pullup 3 Coolant Temp Sensor Volt
BN_E3 OUT_LS7 Low Side Output 7
BN_E4 IN_DE3 Enhanced Digital Input 3
BN_F1 CAN1_LO CAN Bus 1 Low
BN_F2 CAN1_HI CAN Bus 1 High
BN_G1 CAN2_LO CAN Bus 2 Low
BN_G2 CAN2_HI CAN Bus 2 High
BN_G3 IN_DE4 Enhanced Digital Input 4
BN_H1 CAN3_LO CAN Bus 3 Low
BN_H2 CAN3_HI CAN Bus 3 High
BN_H4 IN_A5 Analogue Input 5
BN_J1 IN_A6 Analogue Input 6
BN_J2 IN_A7 Analogue Input 7 Throttle Servo B1 Posn Sensor Tracking Volt
BN_J4 IN_A8 Analogue Input 8 Throttle Servo B1 Posn Sensor Main Volt
BN_K1 IN_A9 Analogue Input 9 Gear Posn Sensor Main Volt
BN_K2 IN_A10 Analogue Input 10
BN_K3 IN_A11 Analogue Input 11
BN_K4 IN_DE5 Enhanced Digital Input 5 Eng Sync Posn
BN_L1 OUT_PLS2 Power Low Side Output 2 Exh Lambda Collector Sensor
BN_L2 IN_ADU1 Analogue Digital Pullup 1 Inlet Air Temp Sensor Volt
BN_L3 OUT_LS8 Low Side Output 8
BN_M4 OUT_LS_STB3 Standby Low Side Output 3 Veh Drive Trim Down Act Out
MCM112 Connector C - GY (Grey)
GY_A1 IN_A12 Analogue Input 12 Eng Oil Pres Sensor Volt
GY_A2 IN_AD2 Analogue Digital Input 2
GY_A3 OUT_LS9 Low Side Output 9
GY_A4 PWR_STB Standby Power ECU Battery Standby Volt
GY_B1 IN_ADU6 Analogue Digital Pullup 6 Eng Oil Temp Sensor Volt
GY_B2 IN_AUC2 Analogue Current Pullup 2
GY_B3 IN_A13 Analogue Input 13 Veh Speed Pitot Pres Sensor Volt
GY_B4 IN_A14 Analogue Input 14 Coolant Pres Sensor Volt
GY_C1 IN_D_STB1 Standby Digital Input 1 Eng Run Sw
GY_C2 IN_D_STB2 Standby Digital Input 2
GY_C3 IN_D_STB3 Standby Digital Input 3
GY_C4 IN_AUC1 Analogue Current Pullup 1 Fuel Tank Level 1 Sensor Volt
GY_D1 OUT_LS10 Low Side Output 10
GY_D2 IN_A15 Analogue Input 15 Inlet Man Pres Sensor Volt
GY_E1 SEN_0V_A Sensor 0V A
GY_E2 SEN_0V_C Sensor 0V C
GY_E3 SEN_0V_B Sensor 0V B
GY_E4 SEN_5V_B Sensor 5V B ECU Sensor 5V0 B Out
GY_F1 SEN_5V_A Sensor 5V A ECU Sensor 5V0 A Out
GY_F2 SEN_5V_C Sensor 5V C ECU Sensor 5V0 C Out
GY_F3 OUT_LS11 Low Side Output 11 Mercury Advanced Sound Controller Out
GY_F4 OUT_PLS1 Power Low Side Output 1 Boost Sol Normal Out
GY_G1 GND Ground
GY_G2 GND Ground
GY_G3 PWR Power
GY_G4 PWR Power
GY_H1 OUT_HB1 Half Bridge Output 1 Throttle Servo B1 Motor Out
GY_H2 OUT_HB2 Half Bridge Output 2 Throttle Servo B1 Motor Out
GY_H3 OUT_HB3 Half Bridge Output 3 Gear Shift Servo Motor Out
GY_H4 OUT_HB4 Half Bridge Output 4 Gear Shift Servo Motor Out
MCM112 Connector X — Expansion
X_1 SEN_0V_F Sensor 0V F
X_2 OUT_INJ9 Injector Output 9
X_3 OUT_INJ10 Injector Output 10
X_4 OUT_INJ11 Injector Output 11
X_5 OUT_INJ12 Injector Output 12
X_6 OUT_INJ13 Injector Output 13
X_7 OUT_INJ14 Injector Output 14
X_8 OUT_INJ15 Injector Output 15
X_9 OUT_INJ16 Injector Output 16
X_10 IO_PWR Power In Out
X_11 IN_A16 Analogue Input 16
X_12 IN_A17 Analogue Input 17
X_13 IN_ADU7 Analogue Digital Pullup 7
X_14 IN_ADU8 Analogue Digital Pullup 8
X_15 IN_AW2 Differential Wideband Input 1.Negative Knock Cyl 1-8 Sensor
X_16 IN_AW3 Differential Wideband Input 2.Positive
X_17 IN_AW4 Differential Wideband Input 2.Negative
X_18 IN_ADU9 Analogue Digital Pullup 9
X_19 IN_ADU10 Analogue Digital Pullup 10
X_20 SEN_0V_G Sensor 0V G
X_21 SEN_0V_H Sensor 0V H
X_22 SEN_5V_D Sensor 5V D
X_23 IN_AW1 Differential Wideband Input 1.Positive Knock Cyl 1-8 Sensor
X_24 CAN4_HI CAN Bus 4 High MoTeC CAN Bus
X_25 CAN4_LO CAN Bus 4 Low MoTeC CAN Bus
X_26 IN_DE6 Enhanced Digital Input 6
X_27 IN_DE7 Enhanced Digital Input 7
X_28 IN_DE8 Enhanced Digital Input 8
X_29
X_30
X_31 ETH_TX+ Ethernet Transmit+ PC Comms
X_32 ETH_TX- Ethernet Transmit- PC Comms
X_33 ETH_RX+ Ethernet Receive+ PC Comms
X_34 ETH_RX- Ethernet Receive- PC Comms
PACKAGE / START FILE DOWNLOAD
Download this Package / Start file from MoTeC Online.
Installation Guides
Name
Version / Part
Published
Download
Name
Version / Part
Published
Download
12102 MCM112 V6 Kit install instructions
12102
Jun 2026
Download
12102
Jun 2026
12102
Jun 2026
Download
KIT CONTENTS
OPERATION
FEATURES
INSTALLATION GUIDE
PINOUT
