Mini R56 2008 N14B16 M1 Package
Part No: #23069
The MINI R56 2008 N14B16 package is a fully programmable replacement for the factory fitted ECU in MINI R56 models.
FEATURES
  • Fully integrates with these original systems: direct injection, stability, dash (partially, see Vehicle Compatibility), power steering, ABS, and purge canister. Lambda control is supported with optional LTC and Bosch LSU4.9 sensor.
  • Pre-configured sensor calibrations for Original Equipment (OE) sensors and engine triggers.
  • Pre-configured control of primary (Direct Injector) fuel system.
  • Optionally configurable secondary (Port Injector) fuel control with a tuneable balance table. Only saturated (high-ohm) secondary injectors are supported in this hardware. Peak-hold (low-ohm) secondary injectors are not supported.
  • Pre-configured reference mode for engine synchronisation and control of 2 camshafts with tuneable inlet and exhaust timing tables.
  • Pre-configured physical settings for engine displacement, fuel density, stoichiometric ratio, fuel pressure, and primary injector linearisation, which allow for simplified engine start-up prior to tuning.
  • Pre-configured CAN messaging for OE systems including ABS / VSC, dashboard and power steering.
  • Pre-configured control of 2 OE coolant fans with temperature thresholds.
  • Pre-configured transient fuelling compensation using physical modelling of fuel film for direct injectors.
  • Pre-configured wheel speed detection via CAN from OE ABS system, allowing gear detection via engine speed / wheel speed estimate.
  • Pre-configured on-board knock control for each cylinder using the OE knock sensor (optionally can be configured to use up to 4 sensors) and selectable centre frequency.
  • Pre-configured camshaft control for inlet and exhaust cams.
  • Configurable boost control with single wastegate actuator. Single and dual solenoids supported.
  • Configurable anti-lag for single turbo variants with ignition timing limit, fuel volume trim, ignition cut, fuel cut, engine speed limit, boost aim and throttle aim tables.
  • Configurable closed loop alternator system for PWM field winding control. OE MINI alternators are not controlled by this subsystem, and will default to 14.0V.
  • Gearbox position detection via sensor or engine speed / wheel speed.
  • Gearbox shift request via up shift switch / down shift switch or gear lever force sensor.
  • Gearbox shift control with ignition cut and engine speed matching.
  • GPS acquisition and logging via CAN or RS232.
  • Configurable launch control with tables.
  • Race time system with tables for ignition timing trim, fuel mixture aim, boost limit, and throttle limit.
  • Engine Load Average channel with tables for engine speed limit, ignition timing trim, fuel mixture aim, boost limit, and throttle limit.
  • ECU CAN Receive from a defined ID base address for data reception from MoTeC devices.
  • 6 configurable driver switches, 4 rotary switches and 6 CAN switches each with 9 positions that can be simultaneously mapped to launch control, pit switch, anti-lag, traction, race time reset, engine speed limit maximum, throttle pedal translation, fuel volume trim, ignition timing, fuel mixture aim, boost limit, traction aim, and traction control range.
  • Pulsed tachometer output with configurable output pin and scaling.
  • Transmission pump output with transmission temperature threshold and hysteresis control.
  • Traction control with tables for aim main, aim compensation, control range.
    • Airbox Mass Flow, Temperature and Pressure
    • Ambient Pressure and Temperature
    • Air Conditioner Refrigerant Pressure
    • Air Conditioner Request
    • Boost Pressure
    • Brake Pressure Front and Rear
    • Brake Switch
    • Coolant Pressure and Temperature
    • Engine Oil Pressure and Temperature
    • Engine Crankcase Pressure
    • Exhaust Pressure Bank 1 and Bank 2
    • Exhaust Temperature (EGT) via TCA Thermocouple Amplifier, Generic CAN, or E888 for Collector, Bank 1 and 2 Collector, and Cylinders 1 to 4.
    • Exhaust Lambda via LTC, LTCN, or PLM for Collector, Bank 1 and 2 Collector, and Cylinders 1 to 4
    • Fuel Pressure and Temperature
    • Fuel Tank Level
    • Gear Position
    • Gear Lever Force
    • Gear Neutral Switch
    • Gear Shift Request
    • Intercooler Temperature
    • Steering Angle and Pressure
    • Transmission Temperature
    • Turbocharger Speed
    • G-Force (acceleration) - Longitudinal, Lateral, Vertical
    • Wheel Speed Front Left, Front Right, Rear Left, and Rear Right
LICENCING
To load the package onto the ECU, the M1 Licence - MINI R56 2008 N14B16 (part number 23069) is required.
VEHICLE COMPATIBILITY
This product includes CAN messaging for basic OE vehicle integration. It caters for OE vehicle systems such as power steering, ABS, starting systems and dashboards. Not all OE dashboard functions are reproduced. Tachometer and speed are supported, while dash warning lights and fuel displays are not.
This product offers configurable closed loop alternator control for PWM field winding control.
OPERATION
When the M142 ECU is installed according to the included wiring pinout, this package mimics most aspects of OE operation as follows.
Start System
The OE vehicle utilises an immobiliser key fob to control power supply to the ECU and to crank the engine when the Start button is pressed. The M142 package does not change this behaviour.
Air Conditioner
There is no interaction between the M1 package and the air conditioner system.
Power Steering
No user interaction or settings are required.
ABS / Stability
While this product uses some sensor information provided by these systems (for example wheel speeds) no further interaction occurs.
Turbocharger Coolant Pump
This pump may be controlled by configuring the Coolant Pump After Run subsystem in the M1 package. When the M142 ECU is installed according to the included wiring pinout, duty cycle should be set to -100% to effect high-side output drive.
Coolant Thermostat
MINI N14 engines have a heated thermostat which may be used to alter cooling system behaviour. Settings for this device are found in the MINI R56 Coolant Thermostat group of the M1 package.
Power Relays
MINI R56 vehicles control the DME and start relays from the ECU. When the M142 ECU is installed according to the included wiring pinout, these outputs may be configured from the MINI R56 Power group of the M1 package.
Some variants of the vehicle may control these relays independently, so actual behaviour may not always match the settings in the M1.
Purge Canister
A simplified purge strategy is available and may be configured from the MINI R56 Fuel Purge group of the M1 package.
WIRING
A wiring schematic is included at the end of this datasheet. The components required to make up a loom based on this schematic may be purchased from MoTeC:
  • 41212 – IGN4
  • 65044 – Connector, 34 pin key 1
  • 65045 – Connector, 26 pin key1
  • 65067 – Connector, M142 34 pin key 2
  • 65068 – Connector, M142 26 pin key 3
  • 61236 - Ethernet cable
  • 68054 - Connector, DTM 4 Pin (F)
  • 68056 - Connector, DTM 6 Pin (F)
These additional components should be sourced independently:
  • MINI N14 ECU Header Connector Set
  • Diode, 1N5404 or similar
  • Resistor, 100 ohm
  • Splices
M142 PINOUT
M142 Connector A - 34 Way
Mating Connector: Tyco Superseal 34 Position Keying 2 – MoTeC #65067
Pin Designation Full Name OE Pin Function Description
A01 AT5 Analogue Temperature Input 5 1k Pull up to SEN_5V_C
A02 AT6 Analogue Temperature Input 6 1k Pull up to SEN_5V_C
A03 AV15 Analogue Voltage Input 15
A04 AV16 Analogue Voltage Input 16
A05 AV17 Analogue Voltage Input 17
A06 INJ_D1A_NEG Direct Injector 1A - A29 Fuel Cylinder 1 Primary Output
A07 INJ_D1A_POS Direct Injector 1A + A04 Fuel Cylinder 1 Primary Output
A08 INJ_D1B_POS Direct Injector 1B +
A09 INJ_D1B_NEG Direct Injector 1B -
A10 SEN_5V0_C1 Sensor 5.0V C
A11 LA_NB1 Lambda Narrow Input 1
A12 LA_NB2 Lambda Narrow Input 2
A13 KNOCK3 Knock Input 3
A14 KNOCK4 Knock Input 4
A15 DIG2 Digital Input 2
A16 DIG3 Digital Input 3
A17 DIG4 Digital Input 4
A18 SEN_5V0_C2 Sensor 5.0V C G04 GPS 5V Supply
A19 SEN_5V0_B2 Sensor 5.0V B
A20 LIN LIN Bus
A21 RS232_RX RS232 Receive G02 GPS Receive
A22 RS232_TX RS232 Transmit
A23 DIG1 Digital Input 1
A24 BAT_NEG3 Battery Negative C53 Chassis Ground
A25 BAT_NEG4 Battery Negative
A26 SEN_0V_C1 Sensor 0V C
A27 SEN_0V_C2 Sensor 0V C G01 GPS 0V Supply
A28 CAN3_HI CAN Bus 3 High
A29 CAN3_LO CAN Bus 3 Low
A30 CAN2_HI CAN Bus 2 High C40 Vehicle 500k CAN Bus
A31 CAN2_LO CAN Bus 2 Low C52 Vehicle 500k CAN Bus
A32 BAT_NEG5 Battery Negative
A33 SEN_0V_B1 Sensor 0V B B07, B08 0V Pulse Sensors: Crank, Inlet Cam
A34 SEN_0V_A1 Sensor 0V A B09, B13, B14, B26, B43 0V Analog Sensors: Throttle Servo, Air Mass Meter, MAP, Coolant, TMAP
M142 Connector B - 26 Way
Mating Connector: Tyco Superseal 26 Position Keying 3 – MoTeC #65068
B01 OUT_HB9 Half Bridge Output 9 B48 Coolant Pump After Run Output
B02 OUT_HB10 Half Bridge Output 10
B03 UDIG8 Universal Digital Input 8 C19 Driver Switch 1
B04 UDIG9 Universal Digital Input 9 A14 Airbox Mass Flow Sensor Digital Input
B05 UDIG10 Universal Digital Input 10
B06 UDIG11 Universal Digital Input 11
B07 UDIG12 Universal Digital Input 12
B08 INJ_LS5 Low Side Injector 5
B09 INJ_LS3 Low Side Injector 3 C11 Fuel Pump Output
B10 AV9 Analogue Voltage Input 9
B11 AV10 Analogue Voltage Input 10
B12 AV11 Analogue Voltage Input 11
B13 BAT_POS Battery Positive C05 ECU Battery Voltage
B14 INJ_LS6 Low Side Injector 6 B06 Fuel Purge Solenoid Output
B15 INJ_LS4 Low Side Injector 4 C28 Power DME Relay Output
B16 AV12 Analogue Voltage Input 12
B17 AV13 Analogue Voltage Input 13
B18 AV14 Analogue Voltage Input 14
B19 BAT_POS Battery Positive C06 ECU Battery Voltage
B20 OUT_HB7 Half Bridge Output 7 A07 Boost Actuator Output
B21 OUT_HB8 Half Bridge Output 8 B49 Coolant Thermostat Output
B22 INJ_D2A_NEG Direct Injector 2A - A27 Fuel Cylinder 2 Primary Output
B23 INJ_D2A_POS Direct Injector 2A + A06 Fuel Cylinder 2 Primary Output
B24 INJ_D2B_POS Direct Injector 2B +
B25 INJ_D2B_NEG Direct Injector 2B -
B26 SEN_5V0_A Sensor 5.0V A C20, C46, A22 5V Analog Sensors: APP, FRP
M142 Connector C - 34 Way
Mating Connector C: Tyco Superseal 34 Position Keying 1 – MoTeC #65044
C01 OUT_HB2 Half Bridge Output 2 A26 Throttle Servo Bank 1 Motor Output
C02 SEN_5V0_A Sensor 5.0V A B36, B37, B38 5V Analog Sensors: Throttle Servo, MAP, TMAP
C03 IGN_LS1 Low Side Ignition 1 to IGN4 J01 IGN4 K01 to A18 Ignition Cylinder 1 Output
C04 IGN_LS2 Low Side Ignition 2 to IGN4 J02 IGN4 K02 to A09 Ignition Cylinder 2 Output
C05 IGN_LS3 Low Side Ignition 3 to IGN4 J03 IGN4 K03 to A17 Ignition Cylinder 3 Output
C06 IGN_LS4 Low Side Ignition 4 to IGN4 J04 IGN4 K04 to A10 Ignition Cylinder 4 Output
C07 IGN_LS5 Low Side Ignition 5
C08 IGN_LS6 Low Side Ignition 6
C09 SEN_5V0_B Sensor 5.0V B B35, B39 5V Pulse Sensors: Crank, Inlet Cam
C10 BAT_NEG1 Battery Negative C03, K05, K06 To IGN4 Power Ground Chassis Ground
C11 BAT_NEG2 Battery Negative C04, L01 To LTC Power Ground Chassis Ground
C12 IGN_LS7 Low Side Ignition 7
C13 IGN_LS8 Low Side Ignition 8
C14 AV1 Analogue Voltage Input 1 B10 Throttle Servo Bank 1 Position Sensor Main
C15 AV2 Analogue Voltage Input 2 B21 Inlet Manifold Pressure Sensor
C16 AV3 Analogue Voltage Input 3 B11 Throttle Servo Bank 1 Position Sensor Tracking
C17 AV4 Analogue Voltage Input 4 C35 Throttle Pedal Sensor Main
C18 OUT_HB1 Half Bridge Output 1 A25 Throttle Servo Bank 1 Motor Output
C19 INJ_D3A_POS Direct Injector 3A + A05 Fuel Cylinder 3 Primary Output
C20 INJ_D3B_POS Direct Injector 3B +
C21 INJ_D4A_POS Direct Injector 4A + A03 Fuel Cylinder 4 Primary Output
C22 INJ_D4B_POS Direct Injector 4B +
C23 INJ_LS1 Low Side Injector 1 C12 Coolant Fan 2 Output
C24 INJ_LS2 Low Side Injector 2 C13 Coolant Fan 1 Output
C25 AV5 Analogue Voltage Input 5 C34 Throttle Pedal Sensor Tracking
C26 BAT_POS Battery Positive C30 ECU Battery Voltage
C27 INJ_D3A_NEG Direct Injector 3A - A30 Fuel Cylinder 3 Primary Output
C28 INJ_D3B_NEG Direct Injector 3B -
C29 INJ_D4A_NEG Direct Injector 4A - A28 Fuel Cylinder 4 Primary Output
C30 INJ_D4B_NEG Direct Injector 4B -
C31 OUT_HB3 Half Bridge Output 3 B45 Fuel Pressure Direct Pump Output
C32 OUT_HB4 Half Bridge Output 4 leave empty leave empty
C33 OUT_HB5 Half Bridge Output 5 A01 Inlet Camshaft Bank 1 Actuator Output
C34 OUT_HB6 Half Bridge Output 6 B47 Turbocharger Bypass Actuator Output
M142 Connector D — 26 way
Mating Connector D: Tyco Superseal 26 Position Keying 1 – MoTeC #65045
D01 UDIG1 Universal Digital Input 1 A13 Engine Speed Reference
D02 UDIG2 Universal Digital Input 2 A16 Inlet Camshaft Bank 1 Position
D03 AT1 Analogue Temperature Input 1 B23 1k Pull up to SEN_5V_A Inlet Manifold Temperature Sensor
D04 AT2 Analogue Temperature Input 2 B32 1k Pull up to SEN_5V_A Coolant Temperature Sensor
D05 AT3 Analogue Temperature Input 3 B40 1k Pull up to SEN_5V_B
D06 AT4 Analogue Temperature Input 4 1k Pull up to SEN_5V_B
D07 KNOCK1 Knock Input 1 B33 Knock Cylinder 1
D08 UDIG3 Universal Digital Input 3 C26 Brake Switch
D09 UDIG4 Universal Digital Input 4 C22 Brake Switch 2
D10 UDIG5 Universal Digital Input 5 C39 Clutch Switch
D11 UDIG6 Universal Digital Input 6 A11 Engine Oil Pressure Low Switch
D12 BAT_BAK Battery Backup C16
D13 KNOCK2 Knock Input 2 B34 Knock Cylinder 1
D14 UDIG7 Universal Digital Input 7
D15 SEN_0V_A Sensor 0V A A20, C44, C47 0V Analog Sensors: APP, FRP
D16 SEN_0V_B Sensor 0V B
D17 CAN1_HI CAN Bus 1 High L03 MoTeC 1Mbit/sec CAN Bus
D18 CAN1_LO CAN Bus 1 Low L02 MoTeC 1Mbit/sec CAN Bus
D19 SEN_6V3 Sensor 6.3V
D20 AV6 Analogue Voltage Input 6 A24 Fuel Pressure Direct Sensor
D21 AV7 Analogue Voltage Input 7
D22 AV8 Analogue Voltage Input 8 A31 Boost Pressure Sensor
D23 ETH_TX+ Ethernet Transmit+ Ethernet Green/White
D24 ETH_TX- Ethernet Transmit- Ethernet Green
D25 ETH_RX+ Ethernet Receive+ Ethernet Orange/White
D26 ETH_RX- Ethernet Receive- Ethernet Orange
ADAPTOR LOOM WIRING SCHEMATIC
PACKAGE DOWNLOAD
Download this package from MoTeC Online.
User Manuals & Guides
Name
Version / Part
Published
Download
Name
Version / Part
Published
Download
M1 Flex Fuel User Guide
Mar 2017
Download
Mar 2017
Mar 2017
Download
M1 Launch Control User Guide
Mar 2017
Download
Mar 2017
Mar 2017
Download
M1 To PDM CAN Messaging User Guide
Aug 2017
Download
Aug 2017
Aug 2017
Download
FEATURES
LICENCING
OPERATION
WIRING
M142 PINOUT
PACKAGE DOWNLOAD
