Nissan VK50VE 2009 M1 Package
Part No: #23007
The Nissan VK50VE 2009 package is based on MoTeC's successful GPR package series and is available on MoTeC M150 ECUs. It is a versatile and adaptable platform that is configured to run the Nissan VK50 engine in the OEM configuration, which includes the Variable Valve Lift system. The package allows for easy changes to engine tuning and hardware.
The product incorporates many ancillary features commonly found on race cars, such as anti-lag, driver switches (pit switch, launch enable, boost trim, etc.), gear shift control, knock control, intercooler sprays, launch control, chassis logging (steering, suspension), gearbox coolant pumps and traction control.
Also accommodated are many of the systems found on modified road vehicles, such as air conditioning control and definable control outputs. Most ECU input and output pin allocations can be user-defined to suit individual requirements.
The product fully integrates with other MoTeC products, and provides pre-defined CAN messaging for all current display loggers/loggers, E888, VCS, GPS, ADR, BR2, PDM, and SLM.
Original Equipment (OE) CAN messaging is not supported and car specific integration is not provided.
FEATURES
  • Pre-configured sensor calibrations for Original Equipment (OE) sensors and engine triggers. Lambda Control is supported with optional LTC with Bosch LSU4.9 sensor or LTCN with NTK sensor.
  • Pre-configured injector calibrations and ignition timings.
  • Pre-configured reference mode for engine synchronisation and control of 4 camshafts with tunable inlet and exhaust timing tables.
  • Pre-configured on-board knock control for each cylinder with OE knock sensor and selectable centre frequency.
  • Pre-configured physical settings for engine displacement, fuel density, stoichiometric ratio, fuel pressure, and injector linearisation, which allow for simplified engine start-up prior to tuning.
  • Pre-configured Engine Efficiency table, engine load and fuel volume calculation (requires additional inlet manifold temperature sensor, DELCO sensor preconfigured).
  • Pre-configured control of the dual bank VVEL variable valve lift system (requires 2 additional external Dual Half Bridges, an additional 100 Ohm resistor has to be wired across each bridge).
  • Pre-configured fuel closed loop.
  • Pre-configured transient fuelling compensation using physical modelling of fuel film.
  • Support of MoTeC devices: ADR, E8XX, PDM, SLM, VCS.
  • Configurable boost control for a single turbo.
  • Configurable anti-lag for single turbo with ignition timing limit, fuel volume trim, ignition cut, engine speed limit, boost aim and throttle aim tables.
  • Support of 2 coolant fans (PWM controlled).
  • Air conditioner support with switched output control.
  • Coolant temperature compensations for engine speed limit, ignition timing, fuel mixture, boost limit.
  • Engine Speed Limiting with ignition cut and/or fuel cut.
  • Gearbox position detection via optional sensor.
  • Gearbox shift request via up shift switch / down shift switch or gear lever force sensor.
  • Gearbox shift control with ignition cut, fuel cut, throttle blip and engine speed matching.
  • GPS acquisition and logging via CAN or RS232.
  • Configurable launch control with tables for launch engine speed, launch throttle limit, launch boost aim, and launch fuel volume trim.
  • Race time system with tables for ignition timing compensation, fuel mixture aim, boost limit, and throttle limit.
  • Idle closed loop control system using drive by wire actuation.
  • Engine Load Average channel with tables for engine speed limit, ignition timing trim, fuel mixture aim, boost limit, and throttle limit.
  • Configurable security for multiple users.
  • Configuration of brake state using a switch or a pressure sensor.
  • Configuration of clutch state using a switch, a position sensor or a pressure sensor.
  • Calculation of clutch slip.
  • ECU internal G-force (acceleration) – longitudinal, lateral, vertical.
  • ECU CAN receive from a defined CAN ID for data reception from MoTeC devices. Support of 3 CAN buses.
  • ECU CAN transmit of the most common channels using standard MoTeC CAN templates. OE CAN messaging is not supported.
  • 6 switches and 4 rotary switches with 9 positions simultaneously mappable to launch control, pit switch, anti-lag, traction, auxiliary time, race time reset, engine speed limit maximum, throttle pedal translation, ignition timing, fuel mixture aim, boost limit, traction aim and traction control range.
  • Analogue tachometer output with configurable output pin and scaling.
  • Transmission pump output with transmission temperature threshold and hysteresis control.
  • Traction control with tables for aim main, aim compensation and control range.
  • Vehicle speed measurement using wheel speed sensors (optional), estimation or GPS.
  • Vehicle speed limiting (pit speed control).
  • Configurable warning system with light and CAN output.
  • Auxiliary time system with tables for ignition timing compensation, fuel volume trim, and fuel mixture aim.
  • 4 auxiliary outputs for PWM control of added actuators:
    • Duty cycle tables using engine speed and throttle or manifold pressure axis'
    • Activation based on inlet manifold pressure or throttle position
    • Auxiliary Output 1 includes tables for ignition timing compensation, fuel volume trim and fuel mixture aim.
    • Airbox mass flow, pressure and temperature
    • Ambient pressure and temperature
    • Boost pressure
    • Brake pressure front and rear
    • Brake switch
    • Clutch pressure and position
    • Clutch switch
    • Coolant pressure and temperature
    • Engine oil pressure and temperature
    • Engine crankcase pressure
    • Exhaust pressure bank 1 and bank 2
    • Exhaust Gas Temperature (EGT) via TCA Thermocouple Amplifier, generic CAN, or E888 for collector, bank 1 and 2 collector, and cylinders 1 to 8
    • Exhaust lambda via LTC, LTCN, or PLM for collector, Bank 1 and 2 Collector, and Cylinders 1 to 8
    • Fuel pressure and temperature
    • Fuel tank level
    • Gear position
    • Gear lever force
    • Gear neutral switch
    • Gear shift request
    • Steering angle and pressure
    • Transmission temperature
    • Turbocharger speed
    • G-force (acceleration) – longitudinal, lateral, vertical
    • Wheel speed sensors front/rear left/right, wired or CAN input.
OPERATIONAL DIFFERENCES
Operation of VVEL differs from the OEM behaviour; it is only operational when the M150 ECU is powered, and the engine is turning and exceeding a specified engine speed threshold.
VK50VE M150 PINOUT
M150 Connector A - 34 Way
Mating Connector: Tyco Superseal 34 Position Keying 2 – MoTeC #65067
Pin Number Designation Full Name OE Pin Function Description
A01 AT5 Analogue Temperature Input 5
A02 AT6 Analogue Temperature Input 6
A03 AV15 Analogue Voltage Input 15
A04 AV16 Analogue Voltage Input 16 Throttle Pedal Sensor Main Voltage
A05 AV17 Analogue Voltage Input 17 Throttle Pedal Sensor Tracking Voltage
A06 IGN_LS9 Low Side Ignition 9
A07 IGN_LS10 Low Side Ignition 10
A08 IGN_LS11 Low Side Ignition 11
A09 IGN_LS12 Low Side Ignition 12
A10 SEN_5V0_C1 Sensor 5.0V C ECU Sensor 5V0 C Voltage
A11 LA_NB1 Lambda Narrow Input 1
A12 LA_NB2 Lambda Narrow Input 2
A13 KNOCK3 Knock Input 3
A14 KNOCK4 Knock Input 4
A15 DIG2 Digital Input 2
A16 DIG3 Digital Input 3
A17 DIG4 Digital Input 4
A18 SEN_5V0_C2 Sensor 5.0V C ECU Sensor 5V0 C Voltage
A19 SEN_5V0_B2 Sensor 5.0V B ECU Sensor 5V0 B Voltage
A20 LIN LIN Bus
A21 RS232_RX RS232 Receive
A22 RS232_TX RS232 Transmit
A23 DIG1 Digital Input 1
A24 BAT_NEG3 Battery Negative
A25 BAT_NEG4 Battery Negative
A26 SEN_0V_C1 Sensor 0V C
A27 SEN_0V_C2 Sensor 0V C
A28 CAN3_HI CAN Bus 3 High
A29 CAN3_LO CAN Bus 3 Low
A30 CAN2_HI CAN Bus 2 High
A31 CAN2_LO CAN Bus 2 Low
A32 BAT_NEG5 Battery Negative
A33 SEN_0V_B1 Sensor 0V B
A34 SEN_0V_A1 Sensor 0V A
M150 Connector B - 26 Way
Mating Connector: Tyco Superseal 26 Position Keying 3 – MoTeC #65068
B01 OUT_HB9 Half Bridge Output 9 Inlet Camshaft Bank 1 Actuator
B02 OUT_HB10 Half Bridge Output 10 Inlet Camshaft Bank 2 Actuator
B03 UDIG8 Universal Digital Input 8
B04 UDIG9 Universal Digital Input 9
B05 UDIG10 Universal Digital Input 10
B06 UDIG11 Universal Digital Input 11
B07 UDIG12 Universal Digital Input 12
B08 INJ_LS5 Low Side Injector 5
B09 INJ_LS3 Low Side Injector 3
B10 AV9 Analogue Voltage Input 9 Inlet Manifold Pressure Sensor Voltage
B11 AV10 Analogue Voltage Input 10
B12 AV11 Analogue Voltage Input 11 Engine Oil Pressure Sensor Voltage
B13 BAT_POS Battery Positive ECU Battery Voltage
B14 INJ_LS6 Low Side Injector 6
B15 INJ_LS4 Low Side Injector 4
B16 AV12 Analogue Voltage Input 12 Fuel Pressure Sensor Voltage
B17 AV13 Analogue Voltage Input 13
B18 AV14 Analogue Voltage Input 14
B19 BAT_POS Battery Positive ECU Battery Voltage
B20 OUT_HB7 Half Bridge Output 7 Valve Lift Bank 2 Servo Motor Output (requires a 100Ohm resistor wired across the output pins)
B21 OUT_HB8 Half Bridge Output 8 Valve Lift Bank 2 Servo Motor Output (requires a 100Ohm resistor wired across the output pins)
B22 INJ_PH9 Peak Hold Injector 9
B23 INJ_PH10 Peak Hold Injector 10
B24 INJ_PH11 Peak Hold Injector 11
B25 INJ_PH12 Peak Hold Injector 12
B26 SEN_5V0_A Sensor 5.0V A ECU Sensor 5V0 A Voltage
M150 Connector C - 34 Way
C01 OUT_HB2 Half Bridge Output 2 Throttle Servo Bank 1 Motor Output
C02 SEN_5V0_A Sensor 5.0V A ECU Sensor 5V0 A Voltage
C03 IGN_LS1 Low Side Ignition 1 Ignition Cylinder 1 Output
C04 IGN_LS2 Low Side Ignition 2 Ignition Cylinder 2 Output
C05 IGN_LS3 Low Side Ignition 3 Ignition Cylinder 3 Output
C06 IGN_LS4 Low Side Ignition 4 Ignition Cylinder 4 Output
C07 IGN_LS5 Low Side Ignition 5 Ignition Cylinder 5 Output
C08 IGN_LS6 Low Side Ignition 6 Ignition Cylinder 6 Output
C09 SEN_5V0_B Sensor 5.0V B ECU Sensor 5V0 B Voltage
C10 BAT_NEG1 Battery Negative
C11 BAT_NEG2 Battery Negative
C12 IGN_LS7 Low Side Ignition 7 Ignition Cylinder 7 Output
C13 IGN_LS8 Low Side Ignition 8 Ignition Cylinder 8 Output
C14 AV1 Analogue Voltage Input 1 Throttle Servo Bank 1 Position Main
C15 AV2 Analogue Voltage Input 2 Throttle Servo Bank 1 Position Tracking
C16 AV3 Analogue Voltage Input 3 Throttle Servo Bank 2 Position Main
C17 AV4 Analogue Voltage Input 4 Throttle Servo Bank 2 Position Tracking
C18 OUT_HB1 Half Bridge Output 1 Throttle Servo Bank 1 Motor Output
C19 INJ_PH1 Peak Hold Injector 1 Fuel Cylinder 1 Output
C20 INJ_PH2 Peak Hold Injector 2 Fuel Cylinder 2 Output
C21 INJ_PH3 Peak Hold Injector 3 Fuel Cylinder 3 Output
C22 INJ_PH4 Peak Hold Injector 4 Fuel Cylinder 4 Output
C23 INJ_LS1 Low Side Injector 1 Exhaust Camshaft Bank 1 Actuator
C24 INJ_LS2 Low Side Injector 2 Exhaust Camshaft Bank 2 Actuator
C25 AV5 Analogue Voltage Input 5 Valve Lift Bank 1 Servo Position Sensor Main Voltage
C26 BAT_POS Battery Positive ECU Battery Voltage
C27 INJ_PH5 Peak Hold Injector 5 Fuel Cylinder 5 Output
C28 INJ_PH6 Peak Hold Injector 6 Fuel Cylinder 6 Output
C29 INJ_PH7 Peak Hold Injector 7 Fuel Cylinder 7 Output
C30 INJ_PH8 Peak Hold Injector 8 Fuel Cylinder 8 Output
C31 OUT_HB3 Half Bridge Output 3 Throttle Servo Bank 2 Motor Output
C32 OUT_HB4 Half Bridge Output 4 Throttle Servo Bank 2 Motor Output
C33 OUT_HB5 Half Bridge Output 5 Valve Lift Bank 1 Servo Motor Output (requires a 100Ohm resistor wired across the output pins)
C34 OUT_HB6 Half Bridge Output 6 Valve Lift Bank 1 Servo Motor Output (requires a 100Ohm resistor wired across the output pins)
M150 Connector D — 26 way
Mating Connector: Tyco Superseal 26 Position Keying 1 – MoTeC #65045
D01 UDIG1 Universal Digital Input 1 Engine Speed Sensor
D02 UDIG2 Universal Digital Input 2 Inlet Camshaft Bank 1 Position
D03 AT1 Analogue Temperature Input 1 1k Pull up to SEN_5V_A Inlet Manifold Temperature Sensor
D04 AT2 Analogue Temperature Input 2 1k Pull up to SEN_5V_A Coolant Temperature Sensor
D05 AT3 Analogue Temperature Input 3 1k Pull up to SEN_5V_B Engine Oil Temperature Sensor
D06 AT4 Analogue Temperature Input 4 Fuel Temperature Sensor Voltage
D07 KNOCK1 Knock Input 1 Knock Sensor 1
D08 UDIG3 Universal Digital Input 3 Inlet Camshaft Bank 2 Position
D09 UDIG4 Universal Digital Input 4 Exhaust Camshaft Bank 1 Position
D10 UDIG5 Universal Digital Input 5 Exhaust Camshaft Bank 2 Position
D11 UDIG6 Universal Digital Input 6
D12 BAT_BAK Battery Backup
D13 KNOCK2 Knock Input 2 Knock Sensor 1
D14 UDIG7 Universal Digital Input 7
D15 SEN_0V_A Sensor 0V A
D16 SEN_0V_B Sensor 0V B
D17 CAN1_HI CAN Bus 1 High
D18 CAN1_LO CAN Bus 1 Low
D19 SEN_6V3 Sensor 6.3V ECU Sensor 6V3 Voltage
D20 AV6 Analogue Voltage Input 6 Valve Lift Bank 1 Servo Position Sensor Tracking Voltage
D21 AV7 Analogue Voltage Input 7 Valve Lift Bank 2 Servo Position Sensor Main Voltage
D22 AV8 Analogue Voltage Input 8 Valve Lift Bank 2 Servo Position Sensor Tracking Voltage
D23 ETH_TX+ Ethernet Transmit+ Ethernet Green/White
D24 ETH_TX- Ethernet Transmit- Ethernet Green
D25 ETH_RX+ Ethernet Receive+ Ethernet Orange/White
D26 ETH_RX- Ethernet Receive- Ethernet
PACKAGE DOWNLOAD
Download this package from MoTeC Online.
User Manuals & Guides
Name
Version / Part
Published
Download
Name
Version / Part
Published
Download
M1 Launch Control User Guide
Mar 2017
Download
Mar 2017
Mar 2017
Download
M1 To PDM CAN Messaging User Guide
Aug 2017
Download
Aug 2017
Aug 2017
Download
FEATURES
VK50VE M150 PINOUT
PACKAGE DOWNLOAD
