Porsche 991.2 2017 M1 Kit
Part No: #11410
This Plug-In Kit provides a complete replacement for the factory OE (original equipment) ECU for the Porsche 911 Turbo 2017-2019. Using existing wiring, the original fuel system and sensors, it delivers convenient installation with fully programmable control. Along with fuel, ignition, throttle and camshaft control, this Kit also supports other OE ECU features, including:
  • Selectable Turbo or Turbo S models
  • Selectable Drive Mode including Normal, Sport, Sport Plus, and Individual using OE controls
  • Full integration of 7-Speed PDK transmission
  • Direct injector with high pressure fuel pump control and optional secondary port injector control (saturated high-ohm injectors only)
  • Cruise control
  • Included LTC Dual connects to OE Lambda sensors
  • All OE dash functionality including warnings
VEHICLE COMPATIBILITY
This product includes CAN messaging for full OE vehicle integration. The Package caters for OE vehicle systems such as power steering, ABS, starting systems and dashboards.
The following table shows compatible vehicles.
Vehicles supported Year Comment
Porsche 911 Turbo 2016 - 2019 Engine MDA.BA
Porsche 911 Turbo S 2016 - 2019 Engine MDB.CA
Porsche 911 GT2 RS 2017 - 2019 Engine MDH.NA
Vehicles not supported Year Comment
Porsche 911 GT3 2017 - 2019 Engine MDG.GA
Porsche 911 GT3 RS 2018 - 2019 Engine MDG.G
KIT CONTENTS
  • 13142M - M142 ECU MARINE
  • 61464 - M142 PORSCHE 991/2 2017 ADAPTOR KIT
    • 61465 - M142 PORSCHE 991/2 2017 ADAPTOR BOX
    • 61451 - M142 PORSCHE 991/1 MOUNTING KIT
    • 61404 - M1 ADAPTOR 250MM 26W KEY 1 STUB LOOM
    • 61405 - M1 ADAPTOR 250MM 26W KEY 3 STUB LOOM
    • 61406 - M1 ADAPTOR 250MM 34W KEY 1 STUB LOOM
    • 61407 - M1 ADAPTOR 250MM 34W KEY 2 STUB LOOM
    • 61467 - PORSCHE 991_2 2017 BREAKOUT LOOM
    • 61301 - LTCD - DUAL LSU LAMBDA TO CAN
    • 61456 - LAMBDA SENSOR EXTENSION LOOM FOR LSU 0.6 METRES
Licence
  • 23609 - M1 LICENCE - PORSCHE 991/2 2017
This Licence is required to run the M142 PORSCHE 991.2 2017 Package in the M142 ECU.
FEATURES
  • This kit fully integrates with these original systems:
    • Direct fuel injection
    • Starting systems
    • Dashboard
    • Transmission Control for Porsche PDK
    • VDC - Stability Control
    • Drive Mode
  • For ease of integration a number of features are pre-configured to suit compatible vehicles:
    • Sensor calibrations for Original Equipment (OE) sensors and engine triggers.
    • Control of primary (Direct Injector) fuel system.
    • Reference mode for engine synchronisation.
    • Physical settings for engine displacement, fuel density, stoichiometric ratio, fuel pressure, and primary injector linearisation, for simplified engine start-up prior to tuning.
    • CAN messaging for OE systems including dashboard and transmission.
    • Boost control with dual wastegate actuators.
    • Launch control
    • Transient fuelling compensation using physical modelling of fuel film for direct injectors.
    • On-board knock control for each cylinder using the OE knock sensors and selectable centre frequency.
    • Lambda control is supported with included LTCD and OE Bosch LSU4.9 sensors.
    • Idle closed loop control system using ignition and throttle servo actuation.
    • Sensing of OE subsystems
      • Exhaust Temperature (EGT) Bank 1 and 2
      • Engine Oil Temperature and Level
      • Coolant Temperature
      • Boost Pressure
      • Fuel Pressure Direct
      • Brake Vacuum Pressure
      • Engine Compartment, Transmission Temperature
      • Steering Angle
    • Control of OE subsystems:
      • Closed loop control of engine oil pressure
      • Coolant bypass
      • Secondary air pump
      • Run on pump
      • Shutoff valve
      • Exhaust sound valve
      • Fan control
      • Switchable valve lift
    • Engine Load Average channel with tables for engine speed limit, ignition timing trim, fuel mixture aim, boost limit, and throttle limit.
  • Configurable features:
    • Configurable closed loop alternator system for PWM field winding control.
  • Included GPR features:
    • Vehicle speed limiting (pit speed control).
    • Race time system with tables for ignition timing trim, fuel mixture aim, boost limit, and throttle limit.
    • Configurable anti-lag for single turbo variants with ignition timing limit, fuel volume trim, ignition cut, fuel cut, engine speed limit, boost aim and throttle aim tables.
    • Traction control with tables for aim main, aim compensation, control range
    • Optionally configurable secondary (Port Injector) fuel control with a tuneable balance table. Note - this ECU does not support Peak/Hold port injectors. Only Saturated (high-ohm) port injectors are suitable.
  • Additional optional integrations:
    • Support of MoTeC devices: E8XX, PDM, SLM, Keypad, Rotary Controller.
    • 8 configurable driver switches, 8 rotary switches and MoTeC Keypad and Rotary Controller support, each with 9 positions that can be simultaneously mapped to launch control, pit switch, anti-lag, traction, race time reset, engine speed limit maximum, throttle lever translation, fuel volume trim, ignition timing, fuel mixture aim, boost limit, traction aim, and traction control range.
    • GPS acquisition and logging via CAN or RS232.
    • ECU CAN Receive from a defined ID base address for data reception from MoTeC devices.
    • Coolant pump output with PWM control.
    • Coolant pump after-run functionality, optionally with additional pump output.
    • Switchable inlet manifold runner with position feedback.
    • Pulsed tachometer output with configurable output pin and scaling.
    • Transmission pump output with transmission temperature threshold and hysteresis control.
      • Airbox Mass Flow, Temperature and Pressure
      • Ambient Temperature
      • Brake Pressure
      • Coolant Pressure
      • Engine Crankcase Pressure
      • Exhaust Pressure
      • Fuel Pressure and Temperature
      • Intercooler Temperature
      • Turbocharger Speed
      • G-Force (acceleration) - Longitudinal, Lateral, Vertical
OPERATION
Reference Mode
The M1 Reference Mode in this Package is locked to the Porsche 991.2pattern.
ECU Power
The M1 ECU will be powered as follows:
  • When the ignition switch is on.
  • When the M1 is connected to the M1 Tune application via Ethernet. Once on, power will remain when the M1 is connected to the M1 Tune application via Ethernet.
Engine Start
This feature operates identically to OE behaviour.
Driver Switches
Various in-car dials and switches are acquired over the CAN bus and assigned to Firmware resources to allow for mode switching in the ECU. See the Help for the main Porsche group in M1 Tune.
Staged Injection (Port Injectors)
A Breakout loom is included that contains 12 V power and outputs to run saturated port injectors. The Fuel Injector Secondary Location setting is set to Not in Use in the provided Package. To enable secondary port injectors, change this setting to reflect the location of the port injectors. Relevant settings will now be exposed so that the port injector characteristics can be configured.
The principle control mechanism is the Fuel Injector Secondary Contribution Main table which determines the balance between primary (direct) and secondary (port) injectors.
Adaptor Box Expansion Outputs
The included Adaptor Box provides additional outputs for some subsystems on the vehicle. These are controlled from the M142 ECU via LIN messaging. If the LIN settings are modified or the LIN wiring to the Adaptor Box is compromised, these outputs will not function, so it is imperative that LIN settings are not changed in the Package.
The Adapter group in the Package provides status information on each of the outputs.
CAN bus 1 on pins 32 and 33 of the Adaptor Box breakout are connected directly to the OE bus which is 500k. Care must be taken not to over-extend this bus nor transmit messages that might conflict with OE communications on this critical vehicle bus. MoTeC suggests all external connects are made to CAN bus 2 on pins 27/28 of the Adaptor Box breakout for additional engine bay CAN connections over and above the currently connected LTCD on CAN bus 2.
Engine Efficiency Model
This product provides two maps for Engine Efficiency to accommodate the Porsche valve lift switching system. The Engine Efficiency Main table is used when the Adaptor Lift Valve State is Enabled. The Engine Efficiency Low Lift table is used when the variable lift system is Disabled.
Fuel Pressure Control - (Lift Pump)
The vehicle uses a PWM controlled low pressure fuel pump (lift pump). The Package is configured without a fuel pressure (lift) sensor, operating the fuel pump controller on the car with the ‘Open Loop’ setting Enabled so it runs directly off the Feed Forward table.
Fuel Pressure Direct Control
The vehicle uses a current controlled continuous high pressure fuel pump (unlike many contemporary engines which use synchronous piston DI pumps). The Fuel Pressure Direct Bank 1 group provides tables to match desired flow with required pump current, and also uses a pump current sensor provided in the Adaptor Box to facilitate closed loop current control. The current control settings for the Package are pre-configured and it is recommended that these settings are not changed. Settings for the pump flow and feed forward may be optimised as required.
Engine Oil Pressure Control
Engine oil pressure is controlled via a closed loop PWM actuator and pressure sensor. Target pressures are set to mimic the behaviour of the OE installation. As insufficient (or excess) oil pressure can cause irreversible damage to an engine, it is recommended that the supplied settings are not changed without extreme caution.
Methanol
This subsystem runs a PWM controlled pump to inject secondary fuel (methanol, water/methanol) with ignition & fuel compensations.
TCM Features
These features aid useful interaction with the OE TCM.
  • Logging: Clutch pressure and shaft speed logging.
  • TCM Clear: Fault code clearing of the TCM
  • Porsche PDK Clutch Re-Learn compatibility with service level OBD port tools. Performing a clutch re-learn allows the transmission to verify the location and thickness of the clutches used to transmit power to the drive wheels. This enables the transmission control computer to make adjustments to clutch engagement as the discs wear over time. A service grade OBD port tool is required to initiate this sequence which will run a correlation routine using the M1 ECU and factory Porsche TCM. This routine requires the PDK transmission is at normal operating temperature (140F / 60C) and will require 10-20 minutes of the operator's time with their foot pressed firmly on the brake throughout the entire procedure.The PDK transmission clutch re-learn function will not operate if the TCM has been flash tuned.
Torque Reduction
This product offers sophisticated torque reduction of the vehicle, by means of various combinations of throttle control, ignition retard, and fuel cut.
Torque reduction is employed via the following subsystems:
  • Gear Up Shift Torque Reduction Main table
  • Engine Oil Level Warning Torque Limit - reduces engine torque when Engine Oil Level is critically low.
  • Porsche Torque Translation - translates calculated torque values to and from the Porsche CAN bus.
  • Porsche TCM Torque Reduction Extend - the ECU can react too quickly to the torque reduction request from the TCM, so this setting can extend the reduction by up to 30 ms.
  • Porsche VDC Torque Limit Gain
  • Torque Demand Bias - allows scaling of torque demand based on throttle pedal.
  • Torque Reduction Limit - limits the maximum torque reduction that can be applied. Can limit excessive ignition retard being applied from high torque reduction requests from the TCM.
  • Torque Reduction Ignition Timing Limit - sets the transition between ignition timing and fuel cut methods of reducing torque.
  • Torque Ideal Generated Scale - used in calculating the generated torque based on Engine Load.
  • Torque Ideal Correction Internal Loss - mapping of torque lost to internal friction and drives.
  • Torque Minimum Feed Forward
INSTALLATION
See below in the "Downloads" section for an "Installation Guide".
PINOUT
M142 Connector A - 34 Way
Mating Connector: Tyco Superseal 34 Position Keying 2 – MoTeC #65067
Pin Designation Full Name OE or Breakout Pin Description
A01 AT5 Analogue Temperature Input 5 T105-047 Engine Oil Temperature Sensor
A02 AT6 Analogue Temperature Input 6 T91-049 Coolant Temperature Sensor 2
A03 AV15 Analogue Voltage Input 15 Breakout-013
A04 AV16 Analogue Voltage Input 16 Breakout-014
A05 AV17 Analogue Voltage Input 17 Breakout-015
A06 INJ_D1A_NEG Direct Injector 1A - T105-064 Fuel Cylinder 1 Primary -
A07 INJ_D1A_POS Direct Injector 1A + T105-065 Fuel Cylinder 1 Primary +
A08 INJ_D1B_POS Direct Injector 1B + T105-044 Fuel Cylinder 4 Primary +
A09 INJ_D1B_NEG Direct Injector 1B - T105-043 Fuel Cylinder 4 Primary -
A10 SEN_5V0_C1 Sensor 5.0V C Breakout-005, 006, 007 Sensor 5V Supply
A11 LA_NB1 Lambda Narrow Input 1
A12 LA_NB2 Lambda Narrow Input 2
A13 KNOCK3 Knock Input 3 T105-028 Knock Sensor Bank 2 +
A14 KNOCK4 Knock Input 4 T105-027 Knock Sensor Bank 2 -
A15 DIG2 Digital Input 2 T105-075 Exhaust Temperature Sensor Bank 2
A16 DIG3 Digital Input 3 T105-073 Oil Level Sensor
A17 DIG4 Digital Input 4
A18 SEN_5V0_C2 Sensor 5.0V C
A19 SEN_5V0_B2 Sensor 5.0V B T91-072 Sensor 5V Supply
A20 LIN LIN Bus
T91-011, 022, 084, 085, 087, 090,
T105-002, 011, 015, 098,
Breakout-003
LIN Comms - LIN Command to Adaptor Expansion
A21 RS232_RX RS232 Receive Breakout-016 Optional GPS Receive
A22 RS232_TX RS232 Transmit
A23 DIG1 Digital Input 1 T105-083 Exhaust Temperature Sensor Bank 1
A24 BAT_NEG1 Battery Negative Breakout-008 Chassis Ground
A25 BAT_NEG2 Battery Negative T91-002 Chassis Ground
A26 SEN_0V_C1 Sensor 0V C Breakout-020, 021, 022, 031 Sensor 0V Supply
A27 SEN_0V_C2 Sensor 0V C
A28 CAN3_HI CAN Bus 3 High
A29 CAN3_LO CAN Bus 3 Low
A30 CAN2_HI CAN Bus 2 High Breakout-028 MoTeC 1Mbps CAN
A31 CAN2_LO CAN Bus 2 Low Breakout-027 MoTeC 1Mbps CAN
A32 BAT_NEG3 Battery Negative T91-004 Chassis Ground
A33 SEN_0V_B1 Sensor 0V B T105-038, 039, 041, 060, 100 Sensor 0V Supply
A34 SEN_0V_A1 Sensor 0V A T105-005, 026, 029, 090, 094 Sensor 0V Supply
M142 Connector B - 26 Way
Mating Connector: Tyco Superseal 26 Position Keying 3 – MoTeC #65068
B01 OUT_HB9 Half Bridge Output 9 T91-018 Starter Relay
B02 OUT_HB10 Half Bridge Output 10 T105-023 Fuel Pressure Direct Bank 1 Pump Output
B03 UDIG8 Universal Digital Input 8 T91-058 Clutch Switch
B04 UDIG9 Universal Digital Input 9 T91-037 Brake Switch
B05 UDIG10 Universal Digital Input 10
B06 UDIG11 Universal Digital Input 11 Breakout-023
B07 UDIG12 Universal Digital Input 12 Breakout-024
B08 INJ_LS5 Low Side Injection 5 Breakout-026 Optional Port Injector
B09 INJ_LS3 Low Side Injection 3 Breakout-018 Optional Port Injector
B10 AV9 Analogue Voltage Input 9
B11 AV10 Analogue Voltage Input 10
B12 AV11 Analogue Voltage Input 11 Breakout-011
B13 BAT_POS1 Battery Positive T91-003, 005, 006, 104 Switched Battery Supply
B14 INJ_LS6 Low Side Injection 6 Breakout-034 Optional Port Injector
B15 INJ_LS4 Low Side Injection 4 Breakout-025 Optional Port Injector
B16 AV12 Analogue Voltage Input 12 Breakout-012
B17 AV13 Analogue Voltage Input 13
B18 AV14 Analogue Voltage Input 14
B19 BAT_POS2 Battery Positive Breakout-002 Optional Port Injector Power Supply
B20 OUT_HB7 Half Bridge Output 7 T105-097 Throttle Servo Bank 1 Motor Output -
B21 OUT_HB8 Half Bridge Output 8 T105-096 Throttle Servo Bank 1 Motor Output +
B22 INJ_D2A_NEG Direct Injector 2A - T105-066 Fuel Cylinder 6 Primary -
B23 INJ_D2A_POS Direct Injector 2A + T105-067 Fuel Cylinder 6 Primary +
B24 INJ_D2B_POS Direct Injector 2B + T105-046 Fuel Cylinder 3 Primary +
B25 INJ_D2B_NEG Direct Injector 2B - T105-045 Fuel Cylinder 3 Primary -
B26 SEN_5V0_A2 Sensor 5.0V A T91-007, 012 Sensor 5V Supply, Sensor 5V Supply
M142 Connector C - 34 Way
C01 OUT_HB2 Half Bridge Output 2 T91-017, 034 Coolant Fan 1 Output
C02 SEN_5V0_A1 Sensor 5.0V A T105-048, 062 Sensor 5V Supply, Sensor 5V Supply
C03 IGN_LS1 Low Side Ignition 1 T105-052 Ignition Cylinder 1
C04 IGN_LS2 Low Side Ignition 2 T105-056 Ignition Cylinder 2
C05 IGN_LS3 Low Side Ignition 3 T105-058 Ignition Cylinder 3
C06 IGN_LS4 Low Side Ignition 4 T105-057 Ignition Cylinder 4
C07 IGN_LS5 Low Side Ignition 5 T105-059 Ignition Cylinder 5
C08 IGN_LS6 Low Side Ignition 6 T105-053 Ignition Cylinder 6
C09 SEN_5V0_B1 Sensor 5.0V B T105-077, 080, 081 Sensor 5V Supply
C10 BAT_NEG4 Battery Negative T91-001 Chassis Ground
C11 BAT_NEG5 Battery Negative Breakout-009 LTC Ground
C12 IGN_LS7 Low Side Ignition 7 T105-036 Coolant Thermostat Output
C13 IGN_LS8 Low Side Ignition 8
T91-081,
Breakout-030
Fuel Pressure Control,
C14 AV1 Analogue Voltage Input 1 T91-028 Brake Vacuum Pressure Sensor
C15 AV2 Analogue Voltage Input 2 T91-076 Throttle Pedal Sensor Main
C16 AV3 Analogue Voltage Input 3 T91-077 Throttle Pedal Sensor Tracking
C17 AV4 Analogue Voltage Input 4 T105-074 Throttle Servo Position Main
C18 OUT_HB1 Half Bridge Output 1 T105-103 Engine Oil Pressure Control Output
C19 INJ_D3A_POS Direct Injector 3A + T105-003 Fuel Cylinder 2 Primary +
C20 INJ_D3B_POS Direct Injector 3B + T105-024 Fuel Cylinder 5 Primary +
C21 INJ_D4A_POS Direct Injector 4A +
C22 INJ_D4B_POS Direct Injector 4B +
C23 INJ_LS1 Low Side Injection 1 Breakout-010 Optional Port Injector
C24 INJ_LS2 Low Side Injection 2 Breakout-017 Optional Port Injector
C25 AV5 Analogue Voltage Input 5 T105-076 Throttle Servo Position Tracking
C26 BAT_POS3 Battery Positive Breakout-001 LTC Power Supply
C27 INJ_D3A_NEG Direct Injector 3A - T105-004 Fuel Cylinder 2 Primary -
C28 INJ_D3B_NEG Direct Injector 3B - T105-025 Fuel Cylinder 5 Primary -
C29 INJ_D4A_NEG Direct Injector 4A -
C30 INJ_D4B_NEG Direct Injector 4B -
C31 OUT_HB3 Half Bridge Output 3 T105-092 Inlet Camshaft Bank 2 Actuator
C32 OUT_HB4 Half Bridge Output 4 T105-019 Inlet Camshaft Bank 1 Actuator
C33 OUT_HB5 Half Bridge Output 5
T105-022,
Breakout-004
Turbocharger Bypass Actuator Output
C34 OUT_HB6 Half Bridge Output 6
T105-018, 021,
Breakout-029
Boost Actuator Normal Output
M142 Connector D - 26 Way
Mating Connector: Tyco Superseal 26 Position Keying 1 – MoTeC #65045
D01 UDIG1 Universal Digital Input 1 T105-072 Engine Speed Reference
D02 UDIG2 Universal Digital Input 2 T105-068 Inlet Camshaft Bank 1 Position
D03 AT1 Analogue Temperature Input 1 T105-050 Engine Compartment Temperature Sensor
D04 AT2 Analogue Temperature Input 2
D05 AT3 Analogue Temperature Input 3 T91-070 Transmission Temperature Sensor
D06 AT4 Analogue Temperature Input 4 T105-054 Coolant Temperature Sensor 1
D07 KNOCK1 Knock Input 1 T105-031 Knock Sensor Bank 1 +
D08 UDIG3 Universal Digital Input 3 T105-070 Inlet Camshaft Bank 2 Position
D09 UDIG4 Universal Digital Input 4 T105-061 Boost Feedback Bank 2
D10 UDIG5 Universal Digital Input 5 T105-032 Boost Feedback Bank 1
D11 UDIG6 Universal Digital Input 6 T105-078 Inlet Manifold Pressure Sensor
D12 BAT_BAK Battery Backup T91-086
D13 KNOCK2 Knock Input 2 T105-030 Knock Sensor Bank 1 -
D14 UDIG7 Universal Digital Input 7 T105-079 Boost Pressure Sensor
D15 SEN_0V_A2 Sensor 0V A T91-019, 083 Sensor 0V Supply
D16 SEN_0V_B2 Sensor 0V B T91-021, 078 Sensor 0V Supply
D17 CAN1_HI CAN Bus 1 High
T91-079,
Breakout-033
OE Powertrain CAN Bus High
D18 CAN1_LO CAN Bus 1 Low
T91-080,
Breakout-032
OE Powertrain CAN Bus Low
D19 SEN_6V3 Sensor 6.3V
D20 AV6 Analogue Voltage Input 6 T105-034 Oil Pressure Sensor
D21 AV7 Analogue Voltage Input 7 Fuel Pressure Direct Current Sensor
D22 AV8 Analogue Voltage Input 8 T105-035 Fuel Pressure Direct Sensor
D23 ETH_TX+ Ethernet Transmit+
D24 ETH_TX- Ethernet Transmit-
D25 ETH_RX+ Ethernet Receive+
D26 ETH_RX- Ethernet Receive-
Breakout Connector E - 34 Way
Mating Connector: Tyco Superseal 34 Position Keying 1 (MoTeC #65044)
Pin Designation Full Name M142 Pin Function
E01 BAT_POS3 Battery Positive C26 LTC Power Supply
E02 BAT_POS2 Battery Positive B19 Optional Port Injector Power Supply
E03 LIN LIN Bus A20
E04 OUT_HB5 Half Bridge Output 5 C33 Turbocharger Bypass Actuator Output
E05 SEN_5V0_C1 Sensor 5.0V C A10 Sensor 5V Supply
E06 SEN_5V0_C1 Sensor 5.0V C A10 Sensor 5V Supply
E07 SEN_5V0_C1 Sensor 5.0V C A10 Sensor 5V Supply
E08 BAT_NEG1 Battery Negative A24 Chassis Ground
E09 BAT_NEG5 Battery Negative C11 LTC Ground
E10 INJ_LS1 Low Side Injection 1 C23 Optional Port Injector
E11 AV11 Analogue Voltage Input 11 B12
E12 AV12 Analogue Voltage Input 12 B16
E13 AV15 Analogue Voltage Input 15 A03
E14 AV16 Analogue Voltage Input 16 A04
E15 AV17 Analogue Voltage Input 17 A05
E16 RS232_RX RS232 Receive A21 Optional GPS Receive
E17 INJ_LS2 Low Side Injection 2 C24 Optional Port Injector
E18 INJ_LS3 Low Side Injection 3 B09 Optional Port Injector
E19 -
E20 SEN_0V_C1 Sensor 0V C A26 Sensor 0V Supply
E21 SEN_0V_C1 Sensor 0V C A26 Sensor 0V Supply
E22 SEN_0V_C1 Sensor 0V C A26 Sensor 0V Supply
E23 UDIG11 Universal Digital Input 11 B06
E24 UDIG12 Universal Digital Input 12 B07
E25 INJ_LS4 Low Side Injection 4 B15 Optional Port Injector
E26 INJ_LS5 Low Side Injection 5 B08 Optional Port Injector
E27 CAN2_Lo CAN Bus 2 Low A31 MoTeC 1Mbps CAN
E28 CAN2_Hi CAN Bus 2 High A30 MoTeC 1Mbps CAN
E29 OUT_HB6 Half Bridge Output 6 C34 Boost Actuator Normal Output
E30 IGN_LS8 Low Side Ignition 8 C13
E31 SEN_0V_C1 Sensor 0V C A26 Sensor 0V Supply
E32 CAN1_Lo CAN Bus 1 Low D18 OE Powertrain CAN Bus Low
E33 CAN1_Hi CAN Bus 1 High D17 OE Powertrain CAN Bus High
E34 INJ_LS6 Low Side Injection 6 B14 Optional Port Injector
PACKAGE DOWNLOAD
Download this package from MoTeC Online.
User Manuals & Guides
Name
Version / Part
Published
Download
Name
Version / Part
Published
Download
M1 Flex Fuel User Guide
Mar 2017
Download
Mar 2017
Mar 2017
Download
M1 Launch Control User Guide
Mar 2017
Download
Mar 2017
Mar 2017
Download
M1 To PDM CAN Messaging User Guide
Aug 2017
Download
Aug 2017
Aug 2017
Download
Installation Guides
Name
Version / Part
Published
Download
Name
Version / Part
Published
Download
Porsche 991.2 2017 M142 Plug-In ECU Kit
11410
Sep 2023
Download
11410
Sep 2023
11410
Sep 2023
Download
KIT CONTENTS
FEATURES
INSTALLATION
OPERATION
PINOUT
PACKAGE DOWNLOAD
