Also Available: NEW 2021 -2023 RXT-X 300 & RXP-X 300 Kit (Part #11311).
This Plug-In Kit is designed as a complete replacement for the factory OE (original equipment) ECU, using existing wiring, sensors and mounting hardware to deliver plug-in convenience with fully programmable control.
The ruggedised M130 ECU is supplied with the Package preloaded, providing complete functionality for the Sea-Doo RX engine.
The Package is based on MoTeC's GPR Package with additional features unique to this engine.
Along with drive-by-wire, fuel and ignition, this Package also allows for knock control and supports OE ECU features, including:
- Starting systems.
- OE dash operation via OE CAN bus.
- Gear forward and reverse operation using the OE iBR (Intelligent Brake and Reverse) system.
- Reverse bucket position monitoring.
- Trim position monitoring
- Operation of OE Cruise and Slow Mode via handle bar controls.
- OE GPS and handlebar operation integrated into the M1 firmware.
- Consistent operation of all factory controls.
The supplied start file contains all calibrations and settings for the sensors, fuel injectors, ignition coils, knock control, throttle servo and cruise control. It also has been calibrated to match the OE factory fuelling and ignition. This saves a significant amount of time as it short cuts the setup process.
Included are numerous ancillary features, such as boost limit, knock control and launch control. It also caters for many systems found on marine vessels that may be useful in a racing context.
The M130 ECU seamlessly integrates with other MoTeC products and provides pre-defined CAN messaging for all current Display/Enclosed Loggers, Power Distribution Modules and other devices including E888, VCS, GPS, ADR, BR2 and SLM.
