Subaru Spec STI 2015 M1 Package
Part No: #23202
This Package, used with an activated MoTeC M150 ECU, is a fully programmable replacement for the factory-fitted Subaru ‘Spec’ STI 2015 ECU.
Included are numerous ancillary features common to race cars, such as anti-lag, driver switches (pit switch, launch enable, boost limit etc.), motorsport gearbox control, knock control, intercooler sprays, launch control, gearbox coolant pumps and traction control. It also caters for many systems found on modified road vehicles that may be useful in a racing context, such as air conditioning control and five definable control outputs.
This Package seamlessly integrates with other MoTeC products and provides pre-defined CAN messaging for all current Display Loggers, Enclosed Loggers, Power Distribution Modules and other devices including E888, VCS, GPS, ADR, BR2 and SLM.
LICENCING
To load the Package onto the ECU, the M1 LICENCE - WRX STI 2007 EJ2xx (part number 23202) is required.
ECU WIRING
If the optional Subaru Adaptor Loom is used, no rewiring is necessary. The loom plugs into the stock wiring harness, using the original sensors and fuel system. All original functions are maintained.
The following components can be supplied together for a complete solution:
  • 13150 - M150 ECU13150: M150 ECU
  • 23202 - M150 Subaru Spec STI 2015 Package
  • 61289 - SUBARU STI 2008-10 M150 ADAPTOR LOOM
VEHICLE COMPATIBILITY
The following table shows compatible vehicles.
Make Year Model Engine
Subaru 2015 WRX STI EJ207
FEATURES
  • Fully integrates with these original systems: ABS/Brakes, SI Drive, Air Conditioning, Start via Key or Button, VDC.
    Lambda control is supported with an optional LTC and Bosch LSU4.9 sensor. See Operation for further details.
  • Pre-configured sensor calibrations for Original Equipment (OE) sensors and engine triggers.
  • Pre-configured control of primary (Port Injector) fuel system.
  • Optionally configurable secondary (Port Injector) fuel control with a tuneable balance table.
  • Pre-configured single fuel operation with selectable properties.
  • Optional alternative fuel operation for Flex Fuel using ethanol composition sensor, or Secondary Fuel operation on secondary injectors.
  • Pre-configured reference mode for engine synchronisation.
  • Pre-configured physical settings for engine displacement, fuel density, stoichiometric ratio, fuel pressure, and primary injector linearisation, which allow for simplified engine startup prior to tuning.
  • Pre-configured CAN messaging for OE systems including dashboard, DCCD, SI Drive, ABS.
  • Pre-configured control for MoTeC SDC3 (with M1-specific firmware upgrade). See Centre Differential Control for further information.
  • Pre-configured control of OE coolant fan with temperature thresholds.
  • Pre-configured transient fuelling compensation using physical modelling of fuel film for port injectors.
  • Idle closed loop control system using ignition and drive by wire actuation.
  • Pre-configured adjustable inlet manifold tumble valves with position feedback.
  • Pre-configured on-board knock control for each cylinder using the OE knock sensor (optionally can be configured to use up to 2 sensors) and multiple centre frequencies.
  • Pre-configured boost control with single wastegate actuator. Single and dual solenoids supported.
  • Pre-configured air conditioner request and clutch control.
  • Configurable anti-lag for single turbo variants with ignition timing limit, fuel volume trim, ignition cut, fuel cut, engine speed limit, boost aim and throttle aim tables.
  • GPS acquisition and logging via CAN or RS232.
  • Lap distance, time and number via GPS, BR2 or switched input, with split and sector options.
  • Support of MoTeC devices: ADR, E8XX, PDM, SLM, VCS.
  • Coolant pump output with PWM control.
  • Coolant pump afterrun functionality, optionally with additional pump output.
  • Configurable launch control with tables.
  • Configurable closed loop alternator system for PWM field winding control.
  • Race time system with tables for ignition timing trim, fuel mixture aim, boost limit and throttle limit.
  • Engine Load Average channel with tables for engine speed limit, ignition timing trim, fuel mixture aim, boost limit, and throttle limit.
  • ECU CAN Receive from a defined ID base address for data reception from MoTeC devices.
  • Vehicle speed limiting (pit speed control).
  • 8 configurable driver switches and 8 rotary switches each with 10 positions that can be simultaneously mapped to launch control, pit switch, anti-lag, traction, race time reset, engine speed limit maximum, throttle pedal translation, fuel volume trim, ignition timing, fuel mixture aim, boost limit, traction aim, and traction control range.
  • Pre-configured pulsed tachometer output with configurable output pin and scaling.
  • Transmission pump output with transmission temperature threshold and hysteresis control.
  • Traction control with tables for aim main, aim compensation, control range.
    • Airbox Mass Flow, Temperature and Pressure
    • Ambient Pressure and Temperature
    • Boost Pressure
    • Brake Pressure Front and Rear
    • Brake Switch
    • Clutch Switch, Pressure and Position
    • Coolant Pressure and Temperature
    • Engine Oil Pressure and Temperature
    • Engine Crankcase Pressure
    • Exhaust Pressure
    • Exhaust Temperature (EGT) via TCA Thermocouple Amplifier, Generic CAN, or E888 for Collector and Cylinders 1 to 4.
    • Exhaust Lambda via LTC, LTCN, or PLM for Collector and Cylinders 1 to 4.
    • Fuel Flow Supply and Return
    • Fuel Pressure and Temperature
    • Fuel Tank Level
    • Intercooler Temperature
    • Steering Angle and Pressure
    • Transmission Temperature and Pressure
    • Turbocharger Speed, Inlet and Outlet Temperature
    • G-Force (acceleration) - Longitudinal, Lateral, Vertical
    • Wastegate Pressure and Position
    • Wheel Speed
OPERATION
Text in colour represents terms used in M1 Tune.
When the M150 ECU is installed according to the included wiring pinout, this Package mimics most aspects of OE operation, as follows.
Starting
Starter motor operation is controlled by the M1 ECU.
STI Start Type
  • Set to Key if the vehicle has a key operated starter.
    In this mode the Start Relay will be turned on with ignition power until Engine Speed is above Start Engine Speed Threshold. The start relay is only to prevent cranking while the engine is running. The clutch must be pressed and key turned to the start position to crank the engine.
    If this mode is incorrectly set on a push button start vehicle, the engine will crank as soon as the clutch is pressed.
  • Set to Button if the vehicle has push button start.
    In this mode the Start Relay will activate when the clutch and start buttons are pressed at the same time. The keyless access module in the vehicle turns on ignition power to the ECU as well as signalling the ECU to crank the engine by the pin connected to Start Request. When this happens the ECU turns on the Start Relay until the engine starts or the Start Timeout elapses.
    If this mode is incorrectly set on a key start vehicle, the starter will not operate.
Alternator
The original equipment alternator on this vehicle has no interaction with the engine ECU. If a replacement alternator is used, the M1 can control the field winding to achieve the desired battery voltage.
Air Conditioning
Air conditioning requests are received from the vehicle via CAN. The M1 ECU controls the Air Conditioner Clutch Output based on the request and additional settings within the Air Conditioner group.
DCCD
SI Drive
The SI Drive switch on the centre console is configured as Driver Rotary Switch 2, allowing control over many features simultaneously.
Each SI Drive mode is mapped numerically:
Position -1 0 1 2 3
Mode Unknown None Sharp Intelligent Sport
Mapping Nil Nil Two Zero One
Mapping for the Unknown or None positions would have no effect on operation, while mapping for Sharp, Intelligent and Sport modes may target such features as Anti-Lag, Traction, Boost Limit or Fuel Mixture Trim.
VDC Disable Switch
The VDC Disable Switch on the centre console is configured as Driver Switch 1, allowing control over many features simultaneously.
This option should be used with caution as the switch still directly controls the OE VDC Disable feature.
VDC Sport Mode Switch
The VDC Sport Mode Switch on the centre console is configured as Driver Switch 2, also allowing control over many features simultaneously.
This option should be used with caution as the switch still directly controls the OE VDC Sport Mode feature.
Vehicle Yaw Rate and Acceleration
These channels are received from the OE Body CAN messaging and may be logged for analysis. Vehicle Acceleration Lateral may be used as a control input for Traction Aim Compensation.
Wheel Speeds
These channels are received from the OE CAN messaging and are used in many subsystems, including Vehicle Speed, Traction Control, Gear Detection and Pit Speed Limit.
If required, OE wheel speed information may be replaced by using hard-wired wheel speed sensors and re-configuring the Wheel Speed resources.
Gear Shift
Operation is configured similarly to that of MoTeC’s M1 GPR Packages.
CENTRE DIFFERENTIAL CONTROL
Two options are available for Differential Control:
  • Original Equipment DCCD ECU is installed on the car.
  • MoTeC SDC3-M1 ECU is installed on the car.
Configuring Original Equipment DCCD Control
When using the OE DCCD controller the only requirement for the M1 is to transmit normal CAN messaging. No user adjustment of centre differential behaviour is available.
To configure M1 operation for the OE DCCD ECU, simply set SDC3 CAN BUS to ‘Not in Use’.
Configuring SDC3-M1 Control
A new unique firmware version for the MoTeC SDC3 allows operation with M1 ECUs that have the Subaru STI 2015 EJ207.February 2016 Package installed. The physical hardware of the SDC3 is unchanged, however the new firmware is not compatible with the existing MoTeC SDC Manager application. Refer to the end of this section for SDC3 firmware upgrade information.
Operation with the M1 Package is configured solely through settings in the M1 ECU via Tune.
To configure M1 operation for the MoTeC SDC3-M1 ECU, simply set SDC3 CAN BUS to ‘CAN Bus 2’ if using the MoTeC Adaptor Loom.
The centre differential control strategy is set up and tuned in the ECU, but follows the same strategy as the standalone SDC3 module using SDC3 Manager for Subaru STI MY08 to MY12 vehicles. The SDC3 User Manual can also be used as a reference to tune the M1 control strategy.
With this method, the SDC3 Module acts as a slave or dumb device. The M1 ECU calculates the required amount of lock based on the tuning and control strategy and sends a 'Lock' amount via CAN to the SDC3. The SDC3 sends back diagnostic information only. The ECU also sends the OE DCCD CAN data to the vehicle, rather than the SDC3 module.
SDC3-M1 Firmware Upgrade
To check which firmware is loaded in the SDC3:
  • Connect to the M1 ECU
  • Navigate to SDC3 Internal Firmware Version
  • If the SDC3-M1 firmware is installed, SDC3 Internal Firmware Version is 1.00.
  • If the legacy V1.26 software is installed, CAN Bus Timeout will be indicated next to SDC3 Internal channels. The SDC3 firmware must be upgraded using the MoTeC SDC3 M1 Upgrade utility.
SDC3-M1 Upgrade Procedure
In the event that a standard SDC3 needs to be field-programmed to operate with the M1 installation, the firmware may be upgraded using the MoTeC SDC3 M1 Upgrade utility as follows:
  • Run the MoTeC SDC3 M1 Upgrade utility.
  • Observe the warning and remove fuses 2 and 7 (‘Combination Meter’) in the passenger compartment fuse panel.
  • Follow the other steps on screen. Select Start Upgrade and then select M1 ECU serial number and CAN Bus 2 (if the Adaptor Loom kit is used).
  • A prompt will indicate that the device firmware is 1.26 (legacy version). Select Rollback.
  • A progress bar will show the firmware update is in progress. Once complete, a prompt will be displayed:
  • The M1 may now be connected in Tune and the SDC3 Internal Firmware Version observed.
SDC3-M1 CAN Messaging
The SDC3-M1 firmware operates as a slave to the M1 ECU and does not incorporate the same CAN messaging as the legacy SDC3 firmware.
The following messages may be incorporated into MoTeC dash displays:
Channel CAN Bus CAN ID Offset Length Values
SDC3 Mode 2 0x380 1 1
1 = Open
2 = Mode 1
3 = Mode 2
4 = Mode 3
5 = Mode 4
6 = Lock
SDC3 Button Press 2 0x164 0 1
0 = Up
2 = Down
4 = Mode
Solenoid Current Avg 2 0x164 1 1 0.1A per bit
Solenoid Current Min 2 0x164 2 1 0.1A per bit
Solenoid Current Max 2 0x164 3 1 0.1A per bit
Solenoid Voltage + 2 0x164 4 1 0.1V per bit
Solenoid Voltage - 2 0x164 5 1 0.1V per bit
Output Duty Cycle 2 0x164 6 2 0.1% per bit
Fault Flags 2 0x165 0 1
1 = Open Circuit Fault
2 = Output Stuck Fault
4 = CAN diagnostic fault
Diagnostic Flags 2 0x165 1 1
1 = Output Circuit Fault
2 = Current Limit Fault
Battery Volts 2 0x165 2 2 0.01V per bit
PINOUT
M150 Connector A - 34 Way
Mating Connector: Tyco Superseal 34 Position Keying 2 – MoTeC #65067
Pin Designation Full Name OE Pin Description
A01 AT5 Analogue Temperature Input 5 A04 Intake Air Temp
A02 AT6 Analogue Temperature Input 6 B24 Cruise Stalk
A03 AV15 Analogue Voltage Input 15 F08 Gear Shift Actuator Pressure (option)
A04 AV16 Analogue Voltage Input 16 F09 Gearbox Position (option)
A05 AV17 Analogue Voltage Input 17 F10 Fuel Lift Pressure (option)
A06 IGN_LS9 Low Side Ignition 9 B14 Sec Air Valve Relay 2
A07 IGN_LS10 Low Side Ignition 10 B15 Sec Air Valve Relay 1
A08 IGN_LS11 Low Side Ignition 11 C08 Sec Air Pump Relay
A09 IGN_LS12 Low Side Ignition 12 C09 A/C Relay
A10 SEN_5V0_C1 Sensor 5.0V C
A11 LA_NB1 Lambda Narrow Input 1
A12 LA_NB2 Lambda Narrow Input 2
A13 KNOCK3 Knock Input 3
A14 KNOCK4 Knock Input 4
A15 DIG2 Digital Input 2 C33 A/C Pressure Switch
A16 DIG3 Digital Input 3 F06 Gear Paddle Up Switch (option)
A17 DIG4 Digital Input 4 F07 Gear Paddle Down Switch (option)
A18 SEN_5V0_C2 Sensor 5.0V C G04 GPS 5 V Supply
A19 SEN_5V0_B2 Sensor 5.0V B B21, B22
A20 LIN LIN Bus
A21 RS232_RX RS232 Receive G02 GPS Receive
A22 RS232_TX RS232 Transmit
A23 DIG1 Digital Input 1 C31 Neutral Pos Switch
A24 BAT_NEG3 Battery Negative D02 Ground
A25 BAT_NEG4 Battery Negative D01 Ground
A26 SEN_0V_C1 Sensor 0V C F01 Gear Shift Sensor 5V Supply (option)
A27 SEN_0V_C2 Sensor 0V C G01 GPS 0 V Supply
A28 CAN3_HI CAN Bus 3 High
A29 CAN3_LO CAN Bus 3 Low
A30 CAN2_HI CAN Bus 2 High C27 Vehicle 500 kbit/sec CAN +
A31 CAN2_LO CAN Bus 2 Low C35 Vehicle 500 kbit/sec CAN -
A32 BAT_NEG5 Battery Negative D06, D26 Ground
A33 SEN_0V_B1 Sensor 0V B A29
A34 SEN_0V_A1 Sensor 0V A A14, A24
M150 Connector B - 26 Way
Mating Connector: Tyco Superseal 26 Position Keying 3 – MoTeC #65068
Pin Designation Full Name OE or Breakout Pin Description
B01 OUT_HB9 Half Bridge Output 9 D23 Tumble Valve RH Closer
B02 OUT_HB10 Half Bridge Output 10 D22 Tumble Valve RH Opener
B03 UDIG8 Universal Digital Input 8 C32 Start Signal
B04 UDIG9 Universal Digital Input 9 A33 Power Steering Oil Pressure Switch
B05 UDIG10 Universal Digital Input 10 B19 Ignition Switch
B06 UDIG11 Universal Digital Input 11 B20 Brake SW1
B07 UDIG12 Universal Digital Input 12 B28 Brake SW2
B08 INJ_LS5 Low Side Injector 5 C18 Fan 1 Relay
B09 INJ_LS3 Low Side Injector 3 C21 Throttle Relay
B10 AV9 Analogue Voltage Input 9 A27 Secondary Air Combination Valve LH Position
B11 AV10 Analogue Voltage Input 10 B32 Fuel Tank Pressure
B12 AV11 Analogue Voltage Input 11
B13 BAT_POS2 Battery Positive C01
B14 INJ_LS6 Low Side Injector 6 C29 Fan 2 Relay
B15 INJ_LS4 Low Side Injector 4 B03 A/C Off signal
B16 AV12 Analogue Voltage Input 12
B17 AV13 Analogue Voltage Input 13
B18 AV14 Analogue Voltage Input 14
B19 BAT_POS3 Battery Positive C01 Switched BAT_POS from Throttle Relay
B20 OUT_HB7 Half Bridge Output 7 D13 Tumble Valve LH Closer
B21 OUT_HB8 Half Bridge Output 8 D12 Tumble Valve LH Opener
B22 INJ_PH9 Peak Hold Injector 9 B13 Crank Monitor
B23 INJ_PH10 Peak Hold Injector 10 C17 Drain Valve
B24 INJ_PH11 Peak Hold Injector 11 C28 Pressure Control Solenoid
B25 INJ_PH12 Peak Hold Injector 12 C11 MIL Lamp
B26 SEN_5V0_A2 Sensor 5.0V A
M150 Connector C - 34 Way
C01 OUT_HB2 Half Bridge Output 2 D04 Throttle Servo Motor Output
C02 SEN_5V0_A1 Sensor 5.0V A
C03 IGN_LS1 Low Side Ignition 1 D18 Ignition Cylinder 1 Output
C04 IGN_LS2 Low Side Ignition 2 D19 Ignition Cylinder 2 Output
C05 IGN_LS3 Low Side Ignition 3 D20 Ignition Cylinder 3 Output
C06 IGN_LS4 Low Side Ignition 4 D21 Ignition Cylinder 4 Output
C07 IGN_LS5 Low Side Ignition 5 D29 Purge Solenoid 1
C08 IGN_LS6 Low Side Ignition 6 D27 Wastegate Solenoid
C09 SEN_5V0_B1 Sensor 5.0V B A19
C10 BAT_NEG1 Battery Negative A05 Ground
C11 BAT_NEG2 Battery Negative D07 Ground
C12 IGN_LS7 Low Side Ignition 7 C12 Fuel Pump Control
C13 IGN_LS8 Low Side Ignition 8 C22 Tachometer
C14 AV1 Analogue Voltage Input 1 B23 Throttle Pedal Sensor Main
C15 AV2 Analogue Voltage Input 2 B31 Throttle Pedal Sensor Tracking
C16 AV3 Analogue Voltage Input 3 A18 Throttle Servo Position Sensor Main
C17 AV4 Analogue Voltage Input 4 A28 Throttle Servo Position Sensor Tracking
C18 OUT_HB1 Half Bridge Output 1 D05 Throttle Servo Motor Output
C19 INJ_PH1 Peak Hold Injector 1 D08 Fuel Cylinder 1 Primary Output
C20 INJ_PH2 Peak Hold Injector 2 D09 Fuel Cylinder 2 Primary Output
C21 INJ_PH3 Peak Hold Injector 3 D10 Fuel Cylinder 3 Primary Output
C22 INJ_PH4 Peak Hold Injector 4 D11 Fuel Cylinder 4 Primary Output
C23 INJ_LS1 Low Side Injector 1 C23 ECU Power Relay Output
C24 INJ_LS2 Low Side Injector 2 C20 Start Relay Output
C25 AV5 Analogue Voltage Input 5 A06 Inlet Manifold Pressure Sensor
C26 BAT_POS1 Battery Positive C01 Switched BAT_POS from Throttle Relay
C27 INJ_PH5 Peak Hold Injector 5 C30 Starter Cut Relay
C28 INJ_PH6 Peak Hold Injector 6 F03 Gear Shift Actuator Pump (option)
C29 INJ_PH7 Peak Hold Injector 7 F04 Gear Shift Actuator Up (option)
C30 INJ_PH8 Peak Hold Injector 8 F05 Gear Shift Actuator Down (option)
C31 OUT_HB3 Half Bridge Output 3 D14 Inlet Cam Solenoid LH
C32 OUT_HB4 Half Bridge Output 4 D16 Inlet Cam Solenoid RH
C33 OUT_HB5 Half Bridge Output 5 D30 Exhaust Cam Solenoid LH
C34 OUT_HB6 Half Bridge Output 6 D24 Exhaust Cam Solenoid RH
M150 Connector D - 26 Way
Mating Connector: Tyco Superseal 26 Position Keying 1 – MoTeC #65045
D01 UDIG1 Universal Digital Input 1 A13 Engine Speed Sensor
D02 UDIG2 Universal Digital Input 2 A21 Inlet Cam Position LH
D03 AT1 Analogue Temperature Input 1 B18 Inlet Air Temperature Sensor
D04 AT2 Analogue Temperature Input 2 A34 Coolant Temperature Sensor
D05 AT3 Analogue Temperature Input 3 B17 Fuel Temperature Sensor
D06 AT4 Analogue Temperature Input 4 B12 Driver Cruise Switch
D07 KNOCK1 Knock Input 1 A15 Knock Sensor 1
D08 UDIG3 Universal Digital Input 3 A11 Inlet Cam Position RH
D09 UDIG4 Universal Digital Input 4 A31 Exhaust Cam Position LH
D10 UDIG5 Universal Digital Input 5 A12 Exhaust Cam Position RH
D11 UDIG6 Universal Digital Input 6 C25 Clutch Switch
D12 BAT_BAK Battery Backup B05 BAT_HOT
D13 KNOCK2 Knock Input 2
D14 UDIG7 Universal Digital Input 7 B33 Fuel Pump Diagnostic
D15 SEN_0V_A2 Sensor 0V A A22
D16 SEN_0V_B2 Sensor 0V B B29, B30, B34, B35, C06, A25
D17 CAN1_HI CAN Bus 1 High L03 MoTeC 1 Mbit/sec CAN
D18 CAN1_LO CAN Bus 1 Low L02 MoTeC 1 Mbit/sec CAN
D19 SEN_6V3 Sensor 6.3V
D20 AV6 Analogue Voltage Input 6 B26 MAF Signal
D21 AV7 Analogue Voltage Input 7 A16 Tumble Generator Valve Position LH
D22 AV8 Analogue Voltage Input 8 A26 Tumble Generator Valve Position RH
D23 ETH_TX+ Ethernet Transmit+ Ethernet Green/White
D24 ETH_TX– Ethernet Transmit- Ethernet Green
D25 ETH_RX+ Ethernet Receive+ Ethernet Orange/White
D26 ETH_RX Ethernet Receive- Ethernet Orange
ADAPTOR LOOM WIRING SCHEMATIC PN 61289
PACKAGE DOWNLOAD
Download this package from MoTeC Online.
LICENCING
ECU WIRING
FEATURES
OPERATION
PINOUT
PACKAGE DOWNLOAD
