The M1 Toyota 86 Engine Swap Package is designed for users who want to fit a different engine into their vehicle.
It is based on MoTeC’s M1 GPR Package with the addition of the following vehicle-specific features:
- CAN Integration for the Toyota 86 to enable the operation of OE power steering, dash, transmission, air conditioning and ABS.
- Received OE CAN messages like wheel speeds, steering angle, push button start and AT range selector data for use in the M1 ECU.
The Package is a versatile and adaptable platform for the operation of piston engines with up to 12 cylinders. It can be configured over a huge range of engine configurations, from controlling a simple, naturally aspirated 4 cylinder to a multi-throttle, boosted V8 with two injectors per cylinder.
Included are many ancillary features commonly found on race cars, such as anti-lag, driver switches (e.g. pit switch, launch enable, boost trim), gearbox control, knock control, intercooler sprays, launch control, traction control, gearbox differential and coolant pumps. Also accommodated are many systems found on modified road vehicles, such as air conditioning.
The product provides pre-defined CAN messaging for full integration with other MoTeC products like Display Loggers, Video, Power Distribution Modules, Expanders, Shift Lights and more.
