Sea-Doo RXT-X 2021 M1 Kit
Part No: #11311
This Plug-In Kit is designed as a complete replacement for the factory OE (original equipment) ECU, using existing wiring, sensors and mounting hardware to deliver plug-in convenience with fully programmable control.
The ruggedised M130 ECU is supplied with the Package preloaded, providing complete functionality for the Sea-Doo RX engine.
The Package is based on MoTeC's GPR Package with additional features unique to this engine.
Along with drive-by-wire, fuel and ignition, this Package also allows for knock control and supports OE ECU features, including:
  • Starting systems.
  • OE dash operation via OE CAN bus.
  • Gear forward and reverse operation using the OE iBR (Intelligent Brake and Reverse) system.
  • Reverse bucket position monitoring.
  • Trim position monitoring
  • Operation of OE Cruise and Slow Mode via handle bar controls.
  • OE GPS and handlebar operation integrated into the M1 firmware.
  • Consistent operation of all factory controls.
The supplied start file contains all calibrations and settings for the sensors, fuel injectors, ignition coils, knock control, throttle servo and cruise control. It also has been calibrated to match the OE factory fuelling and ignition. This saves a significant amount of time as it short cuts the setup process.
Included are numerous ancillary features, such as boost limit, knock control and launch control. It also caters for many systems found on marine vessels that may be useful in a racing context.
The M130 ECU seamlessly integrates with other MoTeC products and provides pre-defined CAN messaging for all current Display/Enclosed Loggers, Power Distribution Modules and other devices including E888, VCS, GPS, ADR, BR2 and SLM.
KIT CONTENTS
Hardware
  • 13130M - M130 ECU MARINE
  • 61478 - SEA-DOO 2021 ADAPTOR KIT M130
    • 41212 - IGN4 IGNITION MODULE - 4 CHANNEL
    • 61225 - NETWORK CABLE RJ45 1.5 METRE
    • 61228 - SEA-DOO 2010 M130 ADAPTOR LOOM
    • 61477 - SEA-DOO 2021 M130 PWC MOUNTING KIT
    • 66002 - RELAY WATER PROOF
Licence
23001 – M1 LICENCE - PERSONAL WATERCRAFT
This Licence is required to run the Sea-Doo RXT-X 2010 Package in the M130M ECU.
FEATURES
  • This kit fully integrates with these Original Equipment (OE) systems:
    • Sea-Doo intelligent Bake and Reverse (iBR)
    • Sea-Doo OE lanyard and starting systems
    • Sea-Doo OE Dash display and warnings
    • Handlebar controls including trim position and Cruise
  • For ease of integration a number of features are pre-configured to suit compatible engines:
    • Control of port injected fuel system.
    • Reference mode for engine synchronisation.
    • Physical settings for engine displacement, fuel density, stoichiometric ratio, fuel pressure, and injector linearisation, for simplified engine start-up prior to tuning.
    • CAN messaging for OE systems including dashboard and iBR.
    • Lambda control is supported with an optional LTC and Bosch LSU4.9 sensor.
    • Idle closed loop control system using ignition and throttle servo actuation.
    • Cruise assist.
    • Engine Start systems
    • Gear detection and selection
    • Throttle Servo control
    • Vehicle Speed from OE GPS
    • Sensor calibrations for OE sensors:
      • Brake Lever
      • Coolant Temperature
      • Cruise assist switches
      • Engine Oil Pressure and Temperature
      • Exhaust Muffler Temperature
      • Fuel Pump
      • Gear Position
      • Inlet Air Temperature
      • Inlet Manifold Pressure
      • Steering Lock
      • Throttle Lever
      • Throttle Servo Position
      • Vehicle Tip Over Switch
  • Included Generic PWC features:
    • On-board knock control for each cylinder using an OE knock sensor.
    • Engine load modelling based on inlet manifold pressure and inlet manifold temperature. Alternatively, allows for throttle based load.
    • Throttle Limit Decrease Rate table for when a throttle limit is requested for smooth throttle reduction.
    • Easy and fast engine tuning using engine efficiency map.
    • Engine Charge Temperature calculation, allows for correction of Inlet Air Temperature.
    • Engine speed limiting with ignition cut and/or fuel cut with individual decay rates for smooth power reduction through Engine Speed Limit Decay table.
    • Transient fuelling compensation using physical modelling of fuel film.
    • Nitrous System with two activation stages and additional fuel pumps, bottle heater control and pressure sensor.
    • Test settings for most outputs, including injection and ignition outputs for easier setup.
    • Assisted engine start with dedicated fuel volume and idle compensations during crank and post start.
    • Configurable turbocharger boost control (using a normal or inverted solenoid output).
    • Coolant temperature compensations for engine speed limit, ignition timing, fuel mixture, boost limit.
    • Coolant Pump output with PWM control.
    • Coolant Pump after-run functionality, optionally with additional pump output.
    • Anti Cavitation system
    • Fuel pump switched output.
    • Race Time system with trim tables for ignition timing compensation, fuel mixture aim, boost limit and throttle limit.
    • Idle Closed Loop control system using ignition, drive by wire actuation or idle solenoid.
    • Idle Bypass control with stepper motor supported.
    • Engine Load Average channel with tables for engine speed limit, ignition timing trim, fuel mixture aim,and throttle limit.
    • Inlet Manifold Flap support.
    • Inlet Manifold Runner support.
    • Closed Loop Alternator Control.
    • Drive by wire throttle servo control.
    • Throttle Lever with translation table.
    • Use of a Throttle Lever sensor or a Throttle Position sensor in case of a cable throttle.
    • Pulsed tachometer output with configurable output pin and scaling.
    • Transmission Pump output with transmission temperature threshold and hysteresis control.
    • Vehicle Speed Limit Control system (DBW-throttle based).
    • Configurable warning system with light and CAN output.
    • Auxiliary time system with tables for ignition timing compensation, fuel volume trim and fuel mixture aim.
    • ECU CAN Receive from a defined CAN ID for data reception from MoTeC devices. Support of 1 (M130/M170) or 3 (M150/M190) CAN buses.
    • ECU CAN Transmit of the most common channels using standard MoTeC CAN templates.
    • Custom CAN Transmit (4 messages).
    • GPS acquisition and logging via CAN and Rs232.
    • Driver Switches
      • 8 configurable driver switches, 8 rotary switches and MoTeC Keypad and Rotary Controller support, each with 10 positions that can be simultaneously mapped to launch control, pit switch, anti-lag, race time reset, engine speed limit maximum, throttle lever translation, fuel volume trim, ignition timing, fuel mixture aim, boost limit, drive trim up switch, drive trim down switch, trim tab starboard up switch, trim tab starboard down switch, trim tab port up switch, trim tab port down switch,
    • Support of MoTeC devices: ADR, E8XX, PDM, SLM, Keypad, Rotary Controller.
    • Launch control.
    • Race time system with tables for ignition timing trim, fuel mixture aim, boost limit, and throttle limit.
    • Configurable anti-lag with ignition timing limit, fuel volume trim, ignition cut, fuel cut, engine speed limit, boost aim and throttle aim tables.
    • 5 auxiliary outputs for PWM control of added actuators
      • Duty Cycle using Engine Speed and Throttle or Manifold Pressure Axis
      • Activation based on inlet manifold pressure or throttle position
      • Auxiliary Output 1 includes tables for Ignition Timing Compensation, Fuel Volume Trim and Fuel Mixture Aim
      • Airbox Mass Flow, Pressure and Temperature
      • Ambient Temperature and Pressure
      • Boost Pressure
      • Coolant Pressure
      • Engine Crankcase Pressure
      • Exhaust Pressure Bank 1 and Bank 2
      • Exhaust Temperature via TCA Thermocouple Amplifier, Generic CAN, or E888 for Collector, Bank 1 and 2 Collector, and Cylinders 1 to 8 (M150/M190: 12 Cylinders)
      • Exhaust Pressure and Temperature
      • Fuel Composition, Flow and Temperature
      • Fuel Flow Supply & Return
      • Fuel Tank Level
      • Fuel Pressure and Temperature
      • Inlet Mass Flow
      • Jet Nozzle Pressure & Angle
      • Steering Angle and Pressure
      • Transmission Pressure A & B
      • Turbocharger Inlet and Outlet Temperature
      • Turbocharger Speed
      • Turbocharger bypass valve
      • Vehicle Acceleration Longitudinal, Lateral & Vertical
      • Vehicle Speed via Pitot and Paddle Wheel
COMPATIBILITY
Model Year Loom revision Sea-Doo Model Setting
RXP-X 300 2021-22 Rev G RXTX2019
2022-23 Rev G RXTX2022
RXT-X 300 2021-22 Rev G RXTX2019
Model years from 2010 - 2020 are supported by the Sea-Doo RXT-X 2010 (Part# 11301).
Other Sea-Doo models including GTI, GTR, GTX, RXT, RXP, SPARK, WAKE can also be run using this kit. However the OE loom schematic should be compared to one of the above models to determine the required loom revision. Additional features that are not included in the above models may not be supported.
OPERATION
  • Starting systems.
INSTALLATION GUIDE
See below in the "Downloads" section for an "Installation Guide".
PINOUT
M130 Connector A - 34 Way
Pin Designation Full Name OE Pin Description
A01 OUT_HB2 Half Bridge Output 2 AL1 Throttle Servo Bank 1 Motor Output+
A02 SEN_5V0_A Sensor 5.0V A AK4, AB4, BJ3, BK1, M03 Sensor 5V supply for Throttle Servo Bank 1 Position Sensor, Inlet Manifold Pressure Sensor, Throttle Lever Sensor, Boost Sensor connector
A03 IGN_LS1 Low Side Ignition 1 D03 Ignition Cylinder 1 Output
A04 IGN_LS2 Low Side Ignition 2 D02 Ignition Cylinder 2 Output
A05 IGN_LS3 Low Side Ignition 3 D01 Ignition Cylinder 3 Output
A06 IGN_LS4 Low Side Ignition 4 BH2, P02 ECU Power Relay Output
A07 IGN_LS5 Low Side Ignition 5
A08 IGN_LS6 Low Side Ignition 6
A09 SEN_5V0_B Sensor 5.0V B AC4 Sensor 5V supply for Vehicle Tip Over Switch
A10 BAT_NEG1 Battery Negative BF2, BL1, BM2, BM3, AG1, AC1 Ground for DESS, M130, TOPS
A11 BAT_NEG2 Battery Negative L01, P01, C05, R85, R87 Ground for LTC, Power Up connector, Ignition Coils, Fuel Pump Relay
A12 IGN_LS7 Low Side Ignition 7
A13 IGN_LS8 Low Side Ignition 8
A14 AV1 Analogue Voltage Input 1 AF3 Throttle Servo Bank 1 Position Sensor Main
A15 AV2 Analogue Voltage Input 2 AG4 Inlet Manifold Pressure Sensor
A16 AV3 Analogue Voltage Input 3 AK3 Throttle Servo Bank 1 Position Sensor Tracking
A17 AV4 Analogue Voltage Input 4 BA3 Throttle Lever Sensor Tracking
A18 OUT_HB1 Half Bridge Output 1 AL2 Throttle Servo Bank 1 Motor Output-
A19 INJ_PH1 Peak Hold Injector 1 AB3 Fuel Cylinder 1 Primary Output
A20 INJ_PH2 Peak Hold Injector 2 AK1 Fuel Cylinder 2 Primary Output
A21 INJ_PH3 Peak Hold Injector 3 AJ1 Fuel Cylinder 3 Primary Output
A22 INJ_PH4 Peak Hold Injector 4
A23 INJ_LS1 Low Side Injector 1
A24 INJ_LS2 Low Side Injector 2 BL4 Engine Start Motor Relay Output
A25 AV5 Analogue Voltage Input 5 BE1 Throttle Lever Sensor Main
A26 BAT_POS1 Battery Positive BM4, L04, V02 12V Supply for M130, LTC, Boost Solenoid connector
A27 INJ_PH5 Peak Hold Injector 5
A28 INJ_PH6 Peak Hold Injector 6
A29 INJ_PH7 Peak Hold Injector 7
A30 INJ_PH8 Peak Hold Injector 8
A31 OUT_HB3 Half Bridge Output 3 V01 Boost Solenoid connector
A32 OUT_HB4 Half Bridge Output 4 R86 Fuel Pump Output
A33 OUT_HB5 Half Bridge Output 5
A34 OUT_HB6 Half Bridge Output 6
M130 Connector B — 26 way
Mating Connector: Tyco Superseal 26 Position Keying 1 – MoTeC #65045
B01 UDIG1 Universal Digital Input 1 AH1 Engine Speed Reference
B02 UDIG2 Universal Digital Input 2 AE2 Engine Synchronisation
B03 AT1 Analogue Temperature Input 1 AH3 Inlet Air Temperature Sensor
B04 AT2 Analogue Temperature Input 2 AA1 Coolant Temperature Sensor
B05 AT3 Analogue Temperature Input 3 AH4 Engine Oil Temperature Sensor
B06 AT4 Analogue Temperature Input 4 BF3 Exhaust Muffler Temperature Sensor
B07 KNOCK1 Knock Input 1 AC3 Knock Sensor
B08 UDIG3 Universal Digital Input 3 BE4 Lanyard Switch
B09 UDIG4 Universal Digital Input 4 AF4 Vehicle Tip Over Switch
B10 UDIG5 Universal Digital Input 5 AE3 Engine Oil Pressure Low Switch
B11 UDIG6 Universal Digital Input 6 BH3 Steering Lock Switch
B12 BAT_BAK Battery Backup
B13 KNOCK2 Knock Input 2
B14 UDIG7 Universal Digital Input 7 BD1 Engine Start Switch
B15 SEN_0V_A Sensor 0V A AG2, K01 Sensor 0V for Knock, Boost Sensor connector
B16 SEN_0V_B Sensor 0V B BE2, BK3, BH1, BB3, AA2, BG4, AD4, AH2, AJ2, AK2, AJ3, AJ4 Sensor 0V for Throttle Lever Sensor, Steering Lock Switch, Throttle Servo Bank 1 Position Sensor, Exhaust Muffler Temperature Sensor, Engine Synchronisation, Inlet Manifold Pressure Sensor, Coolant Temperature Sensor, Engine Speed Reference, Inlet Air Temperature Sensor
B17 CAN1_HI CAN Bus 1 High BC1, L03 500 kbit/sec CAN to Dash, Brake, LTC
B18 CAN1_LO CAN Bus 1 Low BC2, L02 500 kbit/sec CAN to Dash, Brake, LTC
B19 SEN_6V3 Sensor 6.3V
B20 AV6 Analogue Voltage Input 6
B21 AV7 Analogue Voltage Input 7
B22 AV8 Analogue Voltage Input 8 M02 Boost Sensor connector
B23 ETH_TX+ Ethernet Transmit+ Ethernet Green/White
B24 ETH_TX- Ethernet Transmit- Ethernet Green
B25 ETH_RX+ Ethernet Receive+ Ethernet Orange/White
B26 ETH_RX- Ethernet Receive- Ethernet Orange
WIRING MAY 2021 REV G
PACKAGE DOWNLOAD
Download this package from MoTeC Online.
User Manuals & Guides
Name
Version / Part
Published
Download
Name
Version / Part
Published
Download
M1 Flex Fuel User Guide
Mar 2017
Download
Mar 2017
Mar 2017
Download
M1 Launch Control User Guide
Mar 2017
Download
Mar 2017
Mar 2017
Download
M1 To PDM CAN Messaging User Guide
Aug 2017
Download
Aug 2017
Aug 2017
Download
Installation Guides
Name
Version / Part
Published
Download
Name
Version / Part
Published
Download
Sea - Doo RXT-X 2021 M1 Kit
11311
Feb 2024
Download
11311
Feb 2024
11311
Feb 2024
Download
KIT CONTENTS
FEATURES
COMPATIBILITY
OPERATION
INSTALLATION GUIDE
PINOUT
PACKAGE DOWNLOAD
